[gdal-dev] JP2 Segfault
Yves Jacolin yjacolin at free.fr
Fri Jul 22 02:36:21 PDT 2016
Tomaka,
I am using gdal with docker (https://hub.docker.com/r/homme/gdal/). I did not
build gdal by myself even if I am able to do it but I have to use a docker
container as we are in such infrastructure.
Anyway, using SDK 5.3 could be a solution if openjpeg lib is not fast enough.
Y.
On Friday, July 22, 2016 9:26:44 Tomaka, Jacek wrote:
> Yves,
> Have you tried ECW JPEG 2000 SDK 5.2 or 5.3? Is there a reason why you are
> still using old 3.3 version?
> Every version of the SDK contains quite a few improvements and we would also
> be interested in learning about the problems encountered in the supported
> version of the ECW Jp2 SDK.
> There is a license allowing reading ECW and JP2 in non server scenarios
> without any cost.
> Please note that i work for the vendor of ECW JPEG2000 SDK.
> Regards.
> Jacek Tomaka
> ________________________________
> Od: gdal-dev [gdal-dev-bounces at lists.osgeo.org] w imieniu Yves Jacolin
> [yjacolin at free.fr] Wysłano: 22 lipca 2016 15:38
> Do: gdal-dev at lists.osgeo.org
> DW: Jukka Rahkonen
> Temat: Re: [gdal-dev] JP2 Segfault
> Even, Jukka,
> Thank both of you.
> @Even, I though that I get this kind of  issue :) I checked my formats list,
> but maybe at the end of the day, my eyes were tired.
> @Jukka, I did not use two --config flags at the same time, but this
> information is a great confirmation how to manage such multi config flag,
> definitively useful for next time.
> Thanks again,
> Y.
> On Thursday, July 21, 2016 21:23:31 Jukka Rahkonen wrote:
> > Yves Jacolin <yjacolin <at> free.fr> writes:
> > > Hello,
> > > I am working on some JP2 data (total 262 Go) . I started creating a vrt
> > > file and then "gdal_translate" them.
> > > I always have a segfault. I tried to use a GDAL_SKIP config to use
> > > another
> > > driver but it seems that I can successfully do this:
> > > >> Stack trace in bt <<
> > > Starting program: /usr/local/bin/gdal_translate --config GDAL_SKIP
> > > JP2ECW
> > > -- config GDAL_SKIP ECW -a_srs EPSG:2154 -co BIGTIFF=IF_SAFER -co
> > > COMPRESS=JPEG - co TILED=YES -co PHOTOMETRIC=YCBCR
> > > ORTHO_EXPRESS_2015.vrt
> > > ORTHO_EXPRESS_2015.tif
> > clip
> > > Using  --config GDAL_SKIP ECW doesn't change anything.
> > > I can't understand two things:
> > > * first: why libNCSEcw is used instead of openjpeg200 lib?
> > You have used two times the GDAL_SKIP config option
> > --config GDAL_SKIP JP2ECW --config GDAL_SKIP ECW
> > In https://trac.osgeo.org/gdal/wiki/ConfigOptions#GDAL_SKIP it is
> > documented that for skipping several drivers a comma separated list is
> > needed:
> > "The value of this option must be a space delimited list of the short name
> > of the GDAL drivers to unregister."
> > I suppose that with your command only the ECW driver gets skipped and that
> > is not for JPEG2000 at all. Using just one option (or a list) as --config
> > GDAL_SKIP JP2ECW should help you.
> > -Jukka Rahkonen-
> > gdal-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
