[gdal-dev] Using GDAL WMS with https
Carl Godkin cgodkin at gmail.com
Wed Jul 27 14:44:15 PDT 2016
For the first time, I'm trying to use WMS with a server with an "https" URL.
Unless I add <UnsafeSSL>true</UnsafeSSL> to the service description file or
set GDAL_HTTP_UNSAFESSL=YES before running my application, I get an error
like this:
  HTTP status code: 0, error: SSL certificate problem: unable to get local
issuer certificate.
Instead of declaring the site unsafe, I've got a root certificate bundle
that I would like to point at.  I tried setting CURL_CA_BUNDLE (suggested
by the curl documentation) to this file but it doesn't seem to help.
Is there a way to specify a CA bundle in this context?
Thanks,
carl
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160727/cb2b4228/attachment.html>
