[gdal-dev] gdal_translate with -projwin possible bug
Lauren O'Brien leobrien at gmail.com
Wed Jul 27 16:18:36 PDT 2016
Hi Evan,
Ok I thought it might have been at least partially intended. Unfortunately, I think the use case the change is addressing is not what the majority of users are thinking of when they choose projwin.
As Rutger pointed out, the Clipper tool in QGIS 2.14 onwards is now incapable of producing an output that lines up with input, unless the user spends some time doing coordinate math to calculate a precise projwin. That’s a pretty major efficiency loss. Questions about how to clip a raster without resampling or alignment changes appear regularly on stackexchange (see http://gis.stackexchange.com/questions/201204/qgis-clipper-tool-misaliagnment , and http://gis.stackexchange.com/questions/203664/clip-a-tiff-raster-image-using-a-bounding-box-with-python) and gdal_translate with projwin is regularly recommended as the most viable solution.
Jukka, I tried gdal_warp with -te and -tap (one must also input -tr). It was better in that the cell sizes didn’t change, but the output cells moved slightly northwest, such that the center of the input cell became the lower right corner of the output cell. I guess that could be fixed by using gdal_edit with -a_ullr to nudge the output back into place, but that’s still extra work that shouldn’t be necessary.
I think it would be better if projwin’s functionality reverted to its previous behaviour as a default, and that an additional flag be made available for people who do want strict conformance with their specified bounding box as part of a resampling operation.
Either way, the way projwin works in different versions needs to be made explicit in the documentation.
Regards
Lauren
Sent: Thursday, 28 July 2016 2:10 AM
To: gdal-dev at lists.osgeo.org; Jukka Rahkonen
Cc: Lauren O'Brien
Subject: Re: [gdal-dev] gdal_translate with -projwin possible bug
Hi Lauren,
This change was semi intended as far as I can remember (the change that leads
to that was intended, the effect in this use case not) . It dates back to GDAL
2.1.0 where the VRT driver can now support floating point coordinates for
SrcWin / DestWin, and gdal_translate was updated accordingly to not round to
integer pixel coordinates deduced from world coordinates specified through -
projwin.  Sub pixel accuracy makes sense when using with a resampling that is
not nearest neighbour with the -r switch. But indeed for nearest neighbour, it
might result in a non intended shift.
Perhaps a good compromise would be to round to integer for nearest neighbour
only ?
Regarding Jukka's comment,
> I am sure that there are also users who consider that it is a bug if the
> output does not exactly match -projwin.
Using -a_ullr is a way of definining the output bounds for sure.
Even
> Hello all,
> I've noticed what I think may be a bug with gdal_translate, just looking
> for further information before deciding whether to report it.
> In version 1.11.4 and earlier, using the -projwin tag to subset a raster
> produces an output whose cell alignment and content matches the source
> dataset - it just grabs any cells that intersect the box and writes them to
> the output.
> In v2.1.0 (at least in a Windows environment), this no longer occurs. The
> output raster is distorted to match the exact extent of the -projwin
> coordinates. No resampling is involved, but the cell origins shift, and the
> cell sizes are either shrunk or stretched slightly to conform to the
> projwin box. This is a substantial change in behaviour which doesn't appear
> to have been documented.
> From my point of view, its an unwelcome change. I've been using
> gdal_translate with -projwin and vsicurl to clip out sections of large
> national datasets without having to download the whole file first, and
> without needing to know things like the source dataset origin, cellsize etc
> in order to ensure output aligns with input. I need each dataset I clip out
> to 'stack' properly, and to represent an unaltered subset of the source
> data.
> Please let me know if this is a true bug or just an undocumented change,
> and/or if there's a better alternative command to use.
> Regards,
> Lauren O'Brien
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160728/089990ae/attachment.html>
