[gdal-dev] Multithreading issue on pixel-based intensive access (GDAL 2.1.0)
Even Rouault even.rouault at spatialys.com
Thu Jul 28 08:41:55 PDT 2016
On Thursday 28 July 2016 13:11:13 Francisco Javier Calzado wrote:
> Thanks Even,
> I don't want to waste your time, so just before sending any code to be
> tested I would like to be sure it is not a bug from my side. Although I
> usually work with GDAL compiled in 64bits, I had to swap to x86 for these
> tests. When trying to compile in 32bits with Visual Studio 2015 I got the
> following unresolved symbols:
Javier,
Make sure the Visual Studio 32bit environment is properly set up. Check that
WIN64 from nmake.opt is let commented out.
Example of successful build:
https://ci.appveyor.com/project/rouault/gdal-coverage/build/job/8widewvmhgjotxs5
Even
http://www.spatialys.com
