[gdal-dev] RFC: int bFoo -> bool bFoo (simple case)
Mateusz Loskot mateusz at loskot.net
Thu Jun 2 03:21:46 PDT 2016
On 2 June 2016 at 00:59, Kurt Schwehr <schwehr at gmail.com> wrote:
> Hi all
> The large arrays on the stack RFC discussion was impressive.  Here is a
> second RFC.  I tried to use the experience of the first to improve this one.
> Thoughts on the simplest case of int bFoo to bool bFoo?
> https://goo.gl/hdzhXD
Regarding to the gist, namely, the "Proposed solution", looks good.
Thanks.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
