[gdal-dev] Build GDAL for android via NDK
Dmitry Baryshnikov bishop.dev at gmail.com
Sun Jun 12 06:32:25 PDT 2016
Hi Gane,
I build GDAL 2.1 using NDK and borsch build system, based on CMake.
There are some limitations - I only need GDAL in my own c++ library. So
I created swig bindings for my own library, not use GDAL Java bindings
(GDAL java binding is not ready yet).
Here it is the link for library which build GDAL and dependency
libraries - https://github.com/nextgis/nextgis_datastore (especially
https://github.com/nextgis/nextgis_datastore/blob/master/cmake/extlib.cmake)
Here it is an example of using such library -
https://github.com/nextgis/android_maplib/tree/ndk (fixed gradle build
script https://github.com/nextgis/android_maplib/blob/ndk/build.gradle
and NDK makefiles
https://github.com/nextgis/android_maplib/tree/ndk/src/main/jni)
Everything works in Android Studio - GDAL and dependencies downloaded
from github, and build (rather long as build done for each ABI), results
*.so files and headers copied to jni directory and swig bindings too.
The exported functions are ready and work in android application.
This is not finished solution, but I hope it will be helpful.
Best regards,
     Dmitry
10.06.2016 22:07, Gane R пишет:
> Hi all,
> I saw a link for Building GDAL for android on linux
> https://trac.osgeo.org/gdal/wiki/BuildingForAndroid
> Is it updated ?, I tried to build on centOS, It took the android linux
> compiler. The make resulted in a error. gdal 2.1.0
> Is there any updated document or any one having personal experience in
> building GDAL for android or any documentation that has worked will be
> of great help.
> Gane
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160612/853c82f4/attachment.html>
