[gdal-dev] libtool numbering policy
Even Rouault even.rouault at spatialys.com
Tue Jun 14 02:29:40 PDT 2016
A ticket ( https://trac.osgeo.org/gdal/ticket/6542 ) has been raised about
libtool SONAME having not changed between GDAL 2.0.X and GDAL 2.1.0 due to
incrementing both LIBGDAL_CURRENT and LIBGDAL_AGE .
This was raised also in https://trac.osgeo.org/gdal/ticket/4543
Our, more or less implicit, policy up to now was to take just into account the
C ABI, and not the C++ one. Any opinion if we should change it to take into
account the C++ ABI as well ?
If doing that, I can see
- pros: new policy would match the expectations of the C++ API users
- cons: C API users would see soname changes that don't affect them, requiring
recompilation/relinking
Another approach would be to have a libgdal_c.so with C ABI only and
libgdal.so with the rest, ala GEOS, but it is not obvious that the cost to
restructure the GDAL code to implement that, and to existing external code to
adapt for this change, would be worth the advantages.
Even
http://www.spatialys.com
