[gdal-dev] supportive data files for re-projection
Trajce Nikolov NICK trajce.nikolov.nick at gmail.com
Wed Jun 15 11:12:34 PDT 2016
Thanks Kurt , Even .. This is exactly what I need !
Thanks a bunch again!
Cheers,
Nick
On Wed, Jun 15, 2016 at 8:06 PM, Kurt Schwehr <schwehr at gmail.com> wrote:
> Nick,
> What Even said and here is the list of files I use for a very restricted
> build of GDAL with just a minimum of drivers.  e.g. I don't build support
> for S57, so I don't include the S57 only data files.  But if you include
> GML, you might need gml_registry.xml and the files that the xml references.
> -kurt
> Not used only applies to my very funky build env.
>     "compdcs.csv",          // Used by ogr_fromepsg.cpp.
>     "coordinate_axis.csv",  // Used by ogr_fromepsg.cpp, gt_wkt_srs.cpp.
>     "cubewerx_extra.wkt",   // Used by epsg.wkt.
>     // "datum_shift.csv",   // Not used.
>     "ecw_cs.wkt",           // Used by ogr_srs_erm.cpp, ecwdataset.cpp.
>     "ellipsoid.csv",        // Used by geo_normalize.c, ogr_fromepsg.cpp.
>     "epsg.wkt",             // Used by ogr_fromepsg.cpp.
>     "esri_extra.wkt",       // Used by epsg.wkt.
>     "esri_StatePlane_extra.wkt",  // Used by ogr_srs_esri.cpp.
>     "esri_Wisconsin_extra.wkt",   // Used by ogr_srs_esri.cpp.
>     "gcs.csv",              // Used by geo_normalize.c, ogr_fromepsg.cpp,
>                             // ogr_srs_esri.cpp, sqlite.
>     "gcs.override.csv",     // Used by  geo_normalize.c, ogr_fromepsg.cpp.
>     "gdal_datum.csv",       // Used by geo_normalize.c, ogr_srs_esri.cpp,
>                             // gt_wkt_srs.cpp.
>     "geoccs.csv",           // Used by ogr_fromepsg.cpp.
>     "gml_registry.xml",     // Used by gmlregistry.cpp,
> ogrgmldatasource.cpp.
>     "gt_datum.csv",         // Used by nitfdataset.cpp.
>     "gt_ellips.csv",        // Used by nitfdataset.cpp.
>     // "header.dxf",        // Used by ogrdxfwriterds.cpp, which is not
> used.
>     "inspire_cp_BasicPropertyUnit.gfs",  // Used by gml_registry.xml.
>     "inspire_cp_CadastralBoundary.gfs",  // Used by gml_registry.xml.
>     "inspire_cp_CadastralParcel.gfs",    // Used by gml_registry.xml.
>     "inspire_cp_CadastralZoning.gfs",    // Used by gml_registry.xml.
>     "nitf_spec.xml",        // Used by nitffile.c.
>     // "nitf_spec.xsd",     // Used by nitf_spec.xml, which is not used.
>     // "osmconf.ini",       // Used by ogrosmdatasource.cpp, which is not
> used.
>     "ogrvrt.xsd",           // Used by ogrvrtdriver.cpp.
>     "ozi_datum.csv",        // Used by ogr_srs_ozi.cpp.
>     "ozi_ellips.csv",       // Used by ogr_srs_ozi.cpp.
>     "pci_datum.txt",        // Used by ogr_srs_pci.cpp.
>     "pci_ellips.txt",       // Used by ogr_srs_pci.cpp.
>     "pcs.csv",              // Used by  geo_normalize.c, ogr_fromepsg.cpp.
>     "pcs.override.csv",     // Used by geo_normalize.c, ogr_fromepsg.cpp.
>     "prime_meridian.csv",   // Used by geo_normalize.c, ogr_fromepsg.cpp,
> rgdal.
>     "projop_wparm.csv",     // Used by geo_normalize.c.
>     "ruian_vf_ob_v1.gfs",   // Used by gml_registry.xml.
>     "ruian_vf_st_uvoh_v1.gfs",  // Used by gml_registry.xml.
>     "ruian_vf_st_v1.gfs",   // Used by gml_registry.xml.
>     "ruian_vf_v1.gfs",      // Used by gml_registry.xml.
>     // S57 driver.
>     // "s57agencies.csv",   // Not used.
>     // "s57attributes_aml.csv",     // Not used.
>     // "s57attributes.csv",         // Not used.
>     // "s57attributes_iw.csv",      // Not used.
>     // "s57expectedinput.csv",      // Not used.
>     // "s57objectclasses_aml.csv",  // Not used.
>     // "s57objectclasses.csv",      // Not used.
>     // "s57objectclasses_iw.csv",   // Not used.
>     // "seed_2d.dgn",       // DGN driver, not used.
>     // "seed_3d.dgn",       // DGN driver, not used.
>     "stateplane.csv",       // Used by ogr_fromepsg.cpp and IDRISI driver.
>     // "trailer.dxf",       // DXF driver, not used.
>     "unit_of_measure.csv",  // Used by geo_normalize.c, ogr_fromepsg.cpp,
> etc.
>     "vertcs.csv",           // Used by gt_wkt_srs.cpp and ogr_fromepsg.cpp.
>     "vertcs.override.csv",  // Used by ogr_fromepsg.cpp.
> On Wed, Jun 15, 2016 at 10:13 AM, Even Rouault <even.rouault at spatialys.com
> > wrote:
>> Le mercredi 15 juin 2016 18:27:33, Trajce Nikolov NICK a écrit :
>> > Hi Community,
>> > I am new in town ;-). But using gdal for a decade or so. Never been in
>> > situation as now, when I have to filter the data/files that come with
>> gdal
>> > for the installer of the software from our company.
>> > There are bunch of files located in the gdal/data folder and I need to
>> know
>> > which are the ones that are needed for re-projecting of source files
>> > (elevation, vector files)
>> Foreword notice: you break the warranty by cherry picking some of the data
>> files
>> Foreword notice 2: GDAL comes without any warranty (unless you pay a
>> service
>> provider)
>> That said, those ones should be sufficient :
>> $ grep CSVFilename ogr/ogr_fromepsg.cpp
>>     const char *pszFilename = CSVFilename( "unit_of_measure.csv" );
>>     const char *uom_filename = CSVFilename( "unit_of_measure.csv" );
>>     const char *pszFilename = CSVFilename("gcs.override.csv");
>>         pszFilename = CSVFilename("gcs.csv");
>>     const char *PM_FILENAME = CSVFilename("prime_meridian.csv");
>>         CPLAtof(CSVGetField( CSVFilename("ellipsoid.csv" ),
>>     const int nUOMLength = atoi(CSVGetField( CSVFilename("ellipsoid.csv"
>>             CPLStrdup(CSVGetField( CSVFilename("ellipsoid.csv" ),
>>     CPLString osFilename = CSVFilename( "pcs.override.csv" );
>>         osFilename = CSVFilename( "pcs.csv" );
>>     const char *pszFilename = CSVFilename( "pcs.override.csv" );
>>         pszFilename = CSVFilename( "pcs.csv" );
>>     const char *pszFilename = CSVFilename( "coordinate_axis.csv" );
>>     const char  *pszFilename = CSVFilename( "vertcs.override.csv" );
>>         pszFilename = CSVFilename( "vertcs.csv" );
>> //    pszFilename = CSVFilename( "compdcs.override.csv" );
>>     const char  *pszFilename = CSVFilename( "compdcs.csv" );
>>     const char *pszFilename = CSVFilename( "geoccs.csv" );
>>     if( CSVScanFileByName( CSVFilename( "gcs.csv" ),
>>                   CSVFilename( "gcs.csv" ) );
>>         atoi( CSVGetField( CSVFilename( "stateplane.csv" ),
>> gdal_datum.csv might also be needed for shapefiles
>> If you just need to handle a few projections, you could strip much of the
>> information from the above files, but that requires some knowledge...
>> ( you may also need the grids from proj.4 data files )
>> Even
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://schwehr.org
trajce nikolov nick
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160615/6b6a6403/attachment.html>
