[gdal-dev] gdalbuildvrt for multiband files?
Jonathan Greenberg jgrn at illinois.edu
Thu Jun 16 13:00:51 PDT 2016
Folks:
Is there any trick to "stacking" multiple *multiband* files via
gdalbuildvrt for further use with e.g. gdal_translate?  Basically, this
restriction using "separate":
"In that case, only the first band of each dataset will be placed into a
new band."
Is causing problems -- I want to have ALL of the bands in my multiband
files stacked up.  Thanks!
--j
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160616/68fe1f18/attachment.html>
