[gdal-dev] SetSpatialFilter and Spatial Index
Ari Jolma ari.jolma at gmail.com
Thu Jun 16 23:22:39 PDT 2016
The Shapefile driver supports spatial index from .qix file
(http://gdal.org/drv_shapefile.html), so assumably the spatial filter
set by SetSpatialFilter takes advantage of it.
Best regards,
Ari
16.06.2016, 23:04, Tomer kirjoitti:
> Or maybe the question need to be if I set geometry as spatial filter using
> the "SetSpatialFilter" function and then I use the function "GetNextFeature"
> on a layer with spatial index, for instance shp file with qix. It will
> consider the spatial index when fetch the next available feature from this
> layer?
> Thanks again,
> Tomer
> View this message in context: http://osgeo-org.1560.x6.nabble.com/SetSpatialFilter-and-Spatial-Index-tp5271637p5272096.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
