[gdal-dev] GSoC GDAL DWG Support [Week 4]
Even Rouault even.rouault at spatialys.com
Sun Jun 19 06:57:33 PDT 2016
Александр,
Great to see your progress.
Here's a commit to fix a compilation issue:
https://github.com/rouault/gdal_libopencad/commit/0f2a5205ad5e4aaa55283c43c134a3683a60c8b6
> Also, I would like to know which DWG file things would devs like to see in
> Feature attributes fields? Now it contains Thickness, Color (RGB),
> CADGeometryType, ExtendedEntityData (not supported by library yet).
Regarding styling, do you intend exposing it as attributes or using OGR
feature style strings like in the DXF or the Teigha DWG driver ?
> - All libopencad's file I/O was rewritten using VSIF.
I tried the following :
from osgeo import gdal, ogr
data = open('libopencad/tests/data/r2000/triple_circles.dwg').read()
gdal.FileFromMemBuffer('/vsimem/foo.dwg', data)
ds =ogr.Open('/vsimem/foo.dwg')
and got a crash :
Program received signal SIGSEGV, Segmentation fault.
_IO_fread (buf=0x7fffffffd5b0, size=1, count=6, fp=0x0) at iofread.c:43
43	iofread.c: Aucun fichier ou dossier de ce type.
	in iofread.c
(gdb)
(gdb) bt
#0  _IO_fread (buf=0x7fffffffd5b0, size=1, count=6, fp=0x0) at iofread.c:43
#1  0x00007ffff52fb13c in VSIFRead (pBuffer=0x7fffffffd5b0, nSize=1, nCount=6,
fp=0x0) at cpl_vsisimple.cpp:230
#2  0x00007ffff5433a79 in CADFileStreamIO::Read (this=0xa48750, ptr=0x7fffffffd5b0,
size=6) at cadfilestreamio.cpp:109
So I saw you indeed use the VSIF API, and not the VSIF*L API (VSIFOpenL(),
etc....). The former is just a wrapper around the C standard FILE operations,
while the later uses the GDAL virtual file system handlers to have in-memory
file (/vsimem/), compressed file (/vsizip/, /vsitar/) or remote files (/vsicurl/)
Other things I've tried :
* numerous compiler warnings.
* "valgrind --leak-check=full ogrinfo -ro -al -q
libopencad/tests/data/r2000/triple_circles.dwg" shows some memory leaks
* "test_ogrsf -ro libopencad/tests/data/r2000/triple_circles.dwg": a number of
errors regarding taking into attribute & spatial filters (see
OGRDXFLayer::GetNextFeature() for the usual way of taking into account
filters), and finally a crash. test_ogrsf is a kind of "conformance" testing for
OGR drivers. You need to "cd apps; make test_ogrsf" to build it.
Even
http://www.spatialys.com
