[gdal-dev] Not able to build GDAL on RHEL_5 64 bit?
Even Rouault even.rouault at spatialys.com
Fri Jun 24 10:37:40 PDT 2016
Le vendredi 24 juin 2016 19:13:56, sablok a écrit :
> The options --without-sqlite doesn't work :(
Sorry the correct name is --without-sqlite3
> and I am the point of
> frustration now, even though I have all the libraries for sqlite3 in my
> build path all the sqlite2 so's even tried changing the LD_LIBRARY_PATH
> environment variable nothing works
$ ./configure --help | grep sqlite
  --with-sqlite3=[ARG]    use SQLite 3 library [default=yes], optionally
                          specify the prefix for sqlite3 library
So if you configured sqlite3 to be installed in /opt/modern-sqlite3, you have
to run GDAL configure --with-sqlite3=/opt/modern-sqlite3
LD_LIBRARY_PATH should only be needed at runtime.
> http://osgeo-org.1560.x6.nabble.com/Not-able-to-build-GDAL-on-RHEL-5-64-bi
> t-tp5272915p5273253.html Sent from the GDAL - Dev mailing list archive at
> Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
