[gdal-dev] Next maintenance releases
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Fri Jun 24 13:55:03 PDT 2016
Hi again,
And thanks for your swift reply.
After removing the dust from my MSVC 2010 express, I managed to build the trunk version of GDAL on Win 7 Pro (happy that I wrote down the build procedure here: https://trac.osgeo.org/gdal/wiki/SOSI).
The Windows build went fine too and I can now open the SOSI file with a curved geometry, which crashed before.
However, for completeness: I got two SOSI related warnings:
C:\gdal-svn-trunk-2016.06.r\ogrsf_frmts\sosi\ogrsosilayer.cpp(332) : warning C4244: 'argument' : conversion from 'int' to 'float', possible loss of data
C:\gdal-svn-trunk-2016.06.r\ogrsf_frmts\sosi\ogrsosidatatypes.cpp(58) : warning C4244: 'return' : conversion from 'double' to 'float', possible loss of data
> Check that your email address is still defined in https://trac.osgeo.org/gdal/prefs (applies to everyone that hasn't checked recently).
Thanks, the email was missing, I added it now.
> Actually looking at https://trac.osgeo.org/gdal/changeset/34200, I can see that fyba_melding.cpp is compiled on Windows, but not on Unix (but
> that was already the case before). A bit strange...
Might be a Windows-bias at Kartverket...
Kind regards,
Stefan
