[gdal-dev] Building gdal on solaris 11
Andrew Watkins andrew at dcs.bbk.ac.uk
Mon Jun 27 03:44:07 PDT 2016
Hello,
I am trying to build postgis on Solaris 11, but having problems with
gdal part.
I have seen people have said they have compiled it, but worst luck they
have never given any details.
I have tried old and new versions but no luck. Any ideas?
gdal 2.1.0
# CFLAGS="-m64" CXXFLAGS="-m64" LDFLAGS="-m64" ./configure
# gmake
libtool: compile:  g++ -I/export/src/databases/gdal-2.1.0/port
-I/export/src/databases/gdal-2.1.0/gcore
-I/export/src/databases/gdal-2.1.0/alg
-I/export/src/databases/gdal-2.1.0/ogr
-I/export/src/databases/gdal-2.1.0/ogr/ogrsf_frmts
-I/export/src/databases/gdal-2.1.0/gnm
-I/export/src/databases/gdal-2.1.0/apps -m64 -Wall -Wextra -Winit-self
-Wunused-parameter -Wformat -Werror=format-security
-Wno-format-nonliteral -Wlogical-op -Wshadow -Werror=vla
-Wmissing-declarations -Wnon-virtual-dtor -Woverloaded-virtual
-fno-operator-names -DLERC -I libLERC
-I/export/src/databases/gdal-2.1.0/apps -DOGR_ENABLED
-I/export/src/databases/gdal-2.1.0/port -DGDAL_COMPILATION -c
marfa_dataset.cpp  -fPIC -DPIC -o ../o/.libs/marfa_dataset.o
marfa_dataset.cpp: In member function 'CPLXMLNode*
GDAL_MRF::GDALMRFDataset::BuildConfig()':
marfa_dataset.cpp:1072:14: error: expected unqualified-id before numeric
constant
marfa_dataset.cpp:1072:14: error: expected initializer before numeric
constant
marfa_dataset.cpp:1074:66: error: invalid conversion from 'int' to
'CPLXMLNode*'
marfa_dataset.cpp:1074:66: error:   initializing argument 1 of
'CPLXMLNode* CPLCreateXMLElementAndValue(CPLXMLNode*, const char*, const
char*)'
gmake[2]: *** [../o/marfa_dataset.lo] Error 1
gmake[2]: Leaving directory `/export/src/databases/gdal-2.1.0/frmts/mrf'
gmake[1]: *** [mrf-install-obj] Error 2
gmake[1]: Leaving directory `/export/src/databases/gdal-2.1.0/frmts'
gmake: *** [frmts-target] Error 2
gdal 1.11.4
# gmake
/bin/sh /export/src/databases/gdal-1.11.4/libtool --mode=compile
--tag=CC gcc -m64 -DHAVE_SSE_AT_COMPILE_TIME  -Wall
-Wdeclaration-after-statement -I/export/src/databases/gdal-1.11.4/port
-I/export/src/databases/gdal-1.11.4/gcore
-I/export/src/databases/gdal-1.11.4/alg
-I/export/src/databases/gdal-1.11.4/ogr
-I/export/src/databases/gdal-1.11.4/ogr/ogrsf_frmts
-I/export/src/databases/gdal-1.11.4/frmts/vrt -DOGR_ENABLED
-I/export/src/databases/gdal-1.11.4/port  -c -o gdalserver.lo gdalserver.c
libtool: compile:  gcc -m64 -DHAVE_SSE_AT_COMPILE_TIME -Wall
-I/export/src/databases/gdal-1.11.4/port -c gdalserver.c  -fPIC -DPIC -o
.libs/gdalserver.o
In file included from /usr/include/stdio.h:15:0,
                  from
/export/src/databases/gdal-1.11.4/port/cpl_port.h:144,
                  from gdalserver.c:33:
/usr/include/sys/feature_tests.h:358:2: error: #error "Compiler or
options invalid; UNIX 03 and POSIX.1-2001 applications     require the
use of c99"
gmake[1]: *** [gdalserver.lo] Error 1
gmake[1]: Leaving directory `/export/src/databases/gdal-1.11.4/apps'
gmake: *** [apps-target] Error 2
Thanks,
Andrew
Andrew Watkins * Birkbeck, University of London * Computer Science *
* http://notallmicrosoft.blogspot.com *
* UKOUG Systems SIG Chair *
* UKOUG Tech committee *
* tel: 020 7631 6720 *
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160627/cd560a8f/attachment.html>
