[gdal-dev] Amplitude virtual bands for complex datasets ?
Michel Julien Julien.Michel at cnes.fr
Wed Jun 29 00:32:26 PDT 2016
Hi Even, Hi Antonio,
The VRT with custom PixelFunction was actually the first thing I thought of. However, if I understand well those function need to be registered to gdal before opening the VRT, and this must be done in client code, so it will not allow support in Qgis or MapServer for instance. Of course, if Gdal could ship a set of standard pixel functions, the VRT solution would be a solid first step. Maybe this is simpler than derived datasets ? I still think the latter would be nicer, even if I understand that Gdal must avoid mixing natural and derived subdatatsets.
Thanks a lot for your answers,
Julien
-----Message d'origine-----
De : gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] De la part de Antonio Valentino
Envoyé : mardi 28 juin 2016 22:50
À : gdal-dev at lists.osgeo.org
Objet : Re: [gdal-dev] Amplitude virtual bands for complex datasets ?
Hi Even, hi Julien,
Il 28/06/2016 12:39, Even Rouault ha scritto:
> Hi Julien,
>> I would like to discuss an idea that I think would be of great
>> interest for those using Gdal to access complex dataset, such as SLC SAR products.
>> Usually, when one want to visualize such data, looking at the real or
>> imaginary part of the signal does not make much sense. People will
>> compute amplitude, intensity, or even log-intensity and that is what
>> they will look at (phase is to my best knowledge not very useful for
>> visualization, but has a lot of value for processing).
> Which definition do you give to intensity : amplitude^2 ?
>> Computing amplitude and phase from the complex value could be left to
>> the end-user software, but : - Most software do not provide such
>> features (think of Qgis for instance, or MapServer), - If overviews
>> are generated from the real/imaginary image values with interpolation
>> (nearest neighbor would be fine), then the generated overviews will
>> be wrong, because you cannot interpolate complex data this way.
> AFAICS in the code, GDAL currently implements for complex data types :
> nearest neighbour, average on both real and imaginary terms, and
> AVERAGE_MAGPHASE which is average but with renormalization of the
> amplitude so that the AVERAGE_MAGPHASE'ed amplitude is the average of the source amplitudes.
>> I think that Gdal could greatly ease the pain by exposing to the user
>> virtual subdatasets corresponding to the amplitude, phase, intensity
>> and log-intensity, for all complex datasets. In the case of
>> multi-band complex datasets, those virtual subdatasets should also be
>> multi-band, so that polarimetric data could be accessed directly as a
>> multi-band amplitude image for instance.
[CUT]
> Another solution would be to use VRT derived bands (see "Using Derived Bands"
> in http://www.gdal.org/gdal_vrttut.html) and provide a few hard-coded
> pixel functions to compute amplitude, phase, etc...
> and have API facilities like
> GDALRasterBandH GDALCreateDerivedBand( GDALRasterBandH hSrCband, const
> char* pszPixelFunction [, GDALDataType eTargetDT ?] ) that would
> create the in- memory VRT. But I'm aware that doesn't address your
> idea of using unmodified QGIS, MapServer, etc...
Sometime ago I proposed to include in gdal a small set of pixel function.  My use case at the time was mainly relater to SAR SLC data visualization.
There is an open ticket #3367 [1] an also a git repo with pixel functions implemented as gdal plugin [2]
[1] https://trac.osgeo.org/gdal/ticket/3367
[2] https://github.com/avalentino/gdal-pixfun-plugin
I hope this can help is some way.
It would be very nice to have an improved support for SAR complex data.
>> From what I know from Gdal capabilities this is not much work. I
>> could try to do it myself, but I would like to get your feedback
>> first (and some hints on where to start would be useful to me).
> There would be likely changes to do in:
> - GDALOpen(), to detect a syntax like
> "DERIVED_SUBDATASET:Amplitude:original_datasetname" and create the
> appropriate dataset. Hum, or perhaps better, instead of hacking
> GDALOpen(), having a driver that would recognize this syntax and
> instanciate the proper derived dataset.
> - GDALDataset::GetMetadata( pszDomain ) when pszDomain equals "SUBDATASETS"
> -> with the issue I mentionned for drivers that already implement
> -> subdatasets
> and will not call the base method.
> Hum, or perhaps a better solution would be to have a new metadata
> domain "DERIVED_SUBDATASETS". Would solve the potential confusion between "natural"
> and derived subdatasets, and would probably require little/no changes
> in drivers. Would not confuse gdal_translate -sds. Could be used by
> mapserver unmodified. But would require QGIS querying this new metadata domain.
> Even
ciao
Antonio Valentino
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
