[gdal-dev] Pansharpening produces grayscale image?
Rutger kassies at gmail.com
Thu Jun 30 00:15:33 PDT 2016
Does GDAL account for the alignment of the Landsat 8 bands? The center of a
low-res pixel has the same location as the center of a pan-pixel (and thus
other pan-pixels have their center over four corners of low-res pixels.)
Or is this a pre-processing step the user has to do? You could for example
upsample the pan-band to 7.5m and then average again while changing the
extent.
Regards,
Rutger
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Pansharpening-produces-grayscale-image-tp5274075p5274102.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
