[gdal-dev] Amplitude virtual bands for complex datasets ?
Bugbuster philippe.ghesquiere at airbus.com
Thu Jun 30 23:52:10 PDT 2016
Hi Antonio,
I did try the test suite you provided. I tried to convert all VRT images to
GTiff with the simple command :
None of them gave any results.
In each function, I added a debug message when testing the number of source
rasters :
I always get :
If you have any ideas, I would be very grateful to you :-)
Thanks
Philippe
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Amplitude-virtual-bands-for-complex-datasets-tp5273713p5274296.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
