[gdal-dev] GDAL 2.1 release plans
Tamas Szekeres szekerest at gmail.com
Tue Mar 1 10:15:19 PST 2016
Hi Even,
I'm working on the bulk insert option for the MSSQL driver which should be
included in this release. This makes the upload ~20 times faster. Most of
the implementation is already done, but there are some further issues which
should be fixed before adding that part in the codebase.
Best regards,
Tamas
Even Rouault <even.rouault at spatialys.com> ezt írta (2016. március 1., kedd):
> Le lundi 29 février 2016 22:19:03, Sean Gillies a écrit :
> > On Fri, Jan 15, 2016 at 7:11 AM, Even Rouault <
> even.rouault at spatialys.com <javascript:;>>
> > wrote:
> > > Hi,
> > > As I've received lately a few emails asking me about GDAL 2.1, it's
> time
> > > to discuss that publicly.
> > > To keep roughly with our yearly cycle, I think we could probably
> target a
> > > beta
> > > 1 for the beginning of April, with possibly the release happening end
> > > April/beginning May if things go well (optimistic scenario : 3 weeks
> for
> > > betas
> > > + 1 week RCs).
> > > Opinions ? Any candidate for being release manager ?
> > > Cheers,
> > > Even
> > I wish I could raise my hand for the release manager job, but I'm pretty
> > tied up with the GeoJSON WG.
> > I like the time frame you've proposed. There's some work in progress I'd
> > like to see in 2.1 (https://github.com/OSGeo/gdal/pull/98) and 4 weeks
> > should be enough to finish it.
> Hi,
> I intend to cut a 2.1.0 beta1 release on March 31st, which will be the
> feature
> freeze and start point of the 2.1 branch.
> For everybody information, are there major pieces of work (other than the
> above mentionned one) that are expected to land in trunk during this month
> Regarding M support, the following drivers have been updated : Shapefile,
> PostGIS, MEM, FileGDB, OpenFileGDB, CSV, VRT, GeoPackage,
> SQLite/Spatialite.
> (Personal Geodatabase should probably work too, but untested). As well as
> ogrinfo / ogr2ogr. Earlier testers appreciated.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <javascript:;>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160301/ab32a914/attachment.html>
