[gdal-dev] Proposed change regarding wkbCurve, wkbSurface and their M/Z/ZM variants
Even Rouault even.rouault at spatialys.com
Sun Mar 6 07:17:33 PST 2016
During https://trac.osgeo.org/gdal/wiki/rfc61_support_for_measured_geometries
discussion, we introduced wkbCurveM/Z/ZM and wkbSurfaceM/Z/ZM as #define and
not in OGRwkbGeometryType enumeration. This was to be consistent with how
wkbCurve and wkbSurface were themselves introduced in GDAL 2.0 together with
https://trac.osgeo.org/gdal/wiki/rfc49_curve_geometries (actually those 2
#define were implementation details not advertized in RFC 49 itself). The
rationale for keeping them out of the enumeration was that those types were
abstract.
But when revisiting a bit the GeoPackage driver, I see that the GeoPackage
spec can advertize layers of type Curve or Surface, so it would be more
convenient/clean to have them as regular values in the OGRwkbGeometryType
enumeration so they can been more easily dealt with by OGRFromOGCGeomType(),
OGRToOGCGeomType(), etc...  I'm not aware of other drivers that would make use
of such types, but at least ogr2ogr scenarios would be lossless on such GPKG
files.
The argument of abstract vs concrete types is a bit weak, since
OGRwkbGeometryType has already values such as wkbNone or wkbUnknown.
And as RFC 61 has added a number of new constants for M and ZM support, adding
those related to wkbCurveXXX and wkbSurfaceXXXX shouldn't hurt much, as user
code will have to be upgraded anyway.
I've created https://trac.osgeo.org/gdal/ticket/6401 with the proposed (quite
straightforward) patch implementing the change. Let me know if you see issues
with that.
Even
http://www.spatialys.com
