[gdal-dev] GSOC 2016
sarthak agarwal sarthak0415 at gmail.com
Sat Mar 12 13:10:27 PST 2016
Thank you for your reply Dmitry,
Yesterday I was working on ticket 6294
<https://trac.osgeo.org/gdal/ticket/6294> but since you said it was
controversial I started to look around at ticket 6316
<https://trac.osgeo.org/gdal/ticket/6316>,
I figured out that we have to add a else statement after this code
<https://github.com/sarthak-0415/gdal/blob/trunk/gdal/frmts/postgisraster/postgisrasterdataset.cpp>
to give a default value to the ppszDbname in case user dosen’t provide any
database name by default.
And I suggest this small enhancement
<https://github.com/OSGeo/gdal/commit/e7b2e9e9cd946d257cae5dfd196b4786cc2c0e94>
to the code.
Although I am not sure of this line
<https://github.com/sarthak-0415/gdal/blob/trunk/gdal/frmts/postgisraster/postgisrasterdataset.cpp#L2642>
where I want to copy the userName into dbName.
This is a small fix and I wanted to discuss further on it.
I have succesfully build the code on travis
<https://travis-ci.org/sarthak-0415/gdal/builds/115574203>, please check it
once.
I have some doubts regarding some variables and functions for which I am
still reading the code.
I will get back to you if I have some more doubts.
Regards,
Sarthak
On Sat, Mar 12, 2016 at 10:42 PM, Dmitry Baryshnikov <bishop.dev at gmail.com>
wrote:
Hello GSoC students!
> Many of you wrote to different lists and directly for me. I tried to
> systematize your questions.
> 1. First of all each student need to subscribe to soc at lists.osgeo.org
> (the themes connected with organizing moments) and
> gdal-dev at lists.osgeo.org (the themes about ideas, tickets, coding and
> community). Please don't flood both lists the same letters.
> 2. Next - I dig the GDAL tracker and found some tickets worth to be fixed.
> This work help you to understand the project structure and how it works
> (building, testing and so on) and help project to became better.
> The expected result is applied pool request in GDAL main repository at
> github (https://github.com/OSGeo/gdal).
> By the way, after pool request to this repository, the provided fixes are
> tested via TravisC and over test utilities.
> Before making pool request please test it yourself (ubuntu and windows is
> enough, virtualbox or preferable virtualization soft may help here).
> Here is the tickets I think is good for you (it's welcome if community fix
> this list - maybe some tickets need to be excluded or some included):
> - https://trac.osgeo.org/gdal/ticket/2773
> - https://trac.osgeo.org/gdal/ticket/5035 - Alex
> - https://trac.osgeo.org/gdal/ticket/5347
> - https://trac.osgeo.org/gdal/ticket/5592
> - https://trac.osgeo.org/gdal/ticket/5681
> - https://trac.osgeo.org/gdal/ticket/5705
> - https://trac.osgeo.org/gdal/ticket/6185 - Tanuj
> - https://trac.osgeo.org/gdal/ticket/6222
> - https://trac.osgeo.org/gdal/ticket/6246
> - https://trac.osgeo.org/gdal/ticket/6304
> - https://trac.osgeo.org/gdal/ticket/6316
> - https://trac.osgeo.org/gdal/ticket/6385
> I checked tickets already get by students. It's good to discuss with
> community how you plan to fix the tickets before start coding. Also, choose
> tickets carefully, we need students with good skills, so the ticket should
> show your potential. Some of you already choose another tickets, and this
> is normal too, but they need to be discussed too. For example the ticket
> https://trac.osgeo.org/gdal/ticket/6294 is rather controversial.
> 3. We need to see which ideas each of student choose, and what is a plan
> how to release them. You need some discussion with the community what is
> best way or some directions to do it. This is not spoil of the time as your
> ideas come as background for your project announces.
> It'll be nice have more details for some ideas from list
> https://trac.osgeo.org/gdal/wiki/SummerOfCode. The ideas #7,8,9 are very
> briefly.
> Best regards,
>     Dmitry
>-------------- next part --------------
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160313/5ae28c7b/attachment.html>
