[gdal-dev] GSOC 2016
Dmitry Baryshnikov bishop.dev at gmail.com
Mon Mar 14 04:31:53 PDT 2016
Hi Sarthak,
14.03.2016 00:36, sarthak agarwal пишет:
> On Sun, Mar 13, 2016 at 11:07 PM, Even Rouault
> <even.rouault at spatialys.com <mailto:even.rouault at spatialys.com>> wrote:
>     On Sunday 13 March 2016 17:13:27 Dmitry Baryshnikov wrote:
>     > Hi Sarthak,
>     > 1. The GDAL have 2 postgis drivers (raster and vector).
> RIght now I am working on raster part, I still have to figure out
> which part of the code takes care of |vector| postgis driver.
Look at https://github.com/OSGeo/gdal/tree/trunk/gdal/ogr/ogrsf_frmts/pg
>     > 2. You need to add some information to the doxygen comment of
>     > GetConnectionInfo method about new functionality.
> I made changes in the comments, I guess doxygen reads comments in
> between the lines of the code. If still I have to make some changes,
> please tell me.
I figure out that doxygen not parse this file (it seems to me because it
is not public). But, I didn't see explain of PGUSER, PGDATABASEetc. Also
it'll be more useful to extend brief in comment before function name
(https://github.com/sarthak-0415/gdal/blob/1e7970bf38bc06c837ab76d4a185b59089df07f0/gdal/frmts/postgisraster/postgisrasterdataset.cpp#L2463-L2483)
as it done, for example, for mode parameter.
>     > 3. Do you look at psql behaviour? It seems to me the ticket
>     author means
>     > to get the database name not only from environment variable, but
>     also
>     > from the current logged user name.
>     We should be as tolerant as the OGR PG driver is. ie not
>     constraint the user
>     to specify more than what PQconnectdb() requires  (ie it can be
>     potentially
>     empty)
> I have made the changes to make |DBname| to |NULL| if we do not have
> any database name or username.
This is not expected behaviour. As Even wrote if no username nor dbname
provided, the function should get user login and this will be username
and DB name. Do you look at psql sources (this may be rather complex,
and I'm ready to discuss the scope of this work)?
>     > 4. There is a logic error: You form connection string based on
>     > parameters (papszParams) here -
>     https://github.com/sarthak-0415/gdal/blob/trunk/gdal/frmts/postgisraster/pos
>     > tgisrasterdataset.cpp#L2502 , but change the
>     > papszParams below (i.e.
>     > tgisrasterdataset.cpp#L2605). Also changed papszParams never
>     used and only
>     > freed here -
>     > tgisrasterdataset.cpp#L2735.
> I fixed that logical error, and Now it reads the |username| twice
> (once to init the |dbname| and second for the |connection|)
> you can find those changes here
> <https://github.com/OSGeo/gdal/compare/trunk...sarthak-0415:trunk#diff-31df0e62d00ca09f9f11ad2f29e94b540>
> and travis
> <https://travis-ci.org/sarthak-0415/gdal/builds/115730596> for the builds.
Yes, I see. What about your preferable idea for GSoC? What you ideas
about it developing?
By the way, today the  Student Application Period started.
> Regards,
> Sarthak
>     > Best regards,
>     >      Dmitry
>     > 13.03.2016 00:10, sarthak agarwal пишет:
>     > > Thank you for your reply Dmitry,
>     > > Yesterday I was working on ticket 6294
>     > > <https://trac.osgeo.org/gdal/ticket/6294> but since you said
>     it was
>     > > controversial I started to look around at ticket 6316
>     > > <https://trac.osgeo.org/gdal/ticket/6316>,
>     > > I figured out that we have to add a |else| statement after
>     this code
>     <https://github.com/sarthak-0415/gdal/blob/trunk/gdal/frmts/postgisraster/
>     > > postgisrasterdataset.cpp> to give a default value to the
>     |ppszDbname| in
>     > > case user dosen’t
>     > > provide any database name by default.
>     > > And I suggest this small enhancement
>     <https://github.com/OSGeo/gdal/commit/e7b2e9e9cd946d257cae5dfd196b4786cc2c
>     > > 0e94> to the code.
>     > > Although I am not sure of this line
>     > > postgisrasterdataset.cpp#L2642> where I want to copy the
>     |userName| into
>     > > |dbName|.
>     > > This is a small fix and I wanted to discuss further on it.
>     > > I have succesfully build the code on travis
>     > > <https://travis-ci.org/sarthak-0415/gdal/builds/115574203>, please
>     > > check it once.
>     > > I have some doubts regarding some variables and functions for
>     which I
>     > > am still reading the code.
>     > > I will get back to you if I have some more doubts.
>     > > Regards,
>     > > Sarthak
>     > > On Sat, Mar 12, 2016 at 10:42 PM, Dmitry Baryshnikov
>     > > <bishop.dev at gmail.com <mailto:bishop.dev at gmail.com>
>     <mailto:bishop.dev at gmail.com <mailto:bishop.dev at gmail.com>>> wrote:
>     > >     Hello GSoC students!
>     > >     Many of you wrote to different lists and directly for me.
>     I tried
>     > >     to systematize your questions.
>     > >     1. First of all each student need to subscribe to
>     > > soc at lists.osgeo.org <mailto:soc at lists.osgeo.org>
>     <mailto:soc at lists.osgeo.org <mailto:soc at lists.osgeo.org>> (the themes
>     > >     connected with organizing moments) and gdal-dev at lists.osgeo.org
>     <mailto:gdal-dev at lists.osgeo.org>
>     <mailto:gdal-dev at lists.osgeo.org>> (the themes about ideas,
>     > >     tickets, coding and community). Please don't flood both
>     lists the
>     > >     same letters.
>     > >     2. Next - I dig the GDAL tracker and found some tickets
>     worth to
>     > >     be fixed. This work help you to understand the project
>     structure
>     > >     and how it works (building, testing and so on) and help
>     project to
>     > >     became better.
>     > >     The expected result is applied pool request in GDAL main
>     > >     repository at github (https://github.com/OSGeo/gdal).
>     > >     By the way, after pool request to this repository, the
>     provided
>     > >     fixes are tested via TravisC and over test utilities.
>     > >     Before making pool request please test it yourself (ubuntu and
>     > >     windows is enough, virtualbox or preferable virtualization
>     soft
>     > >     may help here).
>     > >     Here is the tickets I think is good for you (it's welcome if
>     > >     community fix this list - maybe some tickets need to be
>     excluded
>     > >     or some included):
>     > >     - https://trac.osgeo.org/gdal/ticket/2773
>     > >     - https://trac.osgeo.org/gdal/ticket/5035 - Alex
>     > >     - https://trac.osgeo.org/gdal/ticket/5347
>     > >     - https://trac.osgeo.org/gdal/ticket/5592
>     > >     - https://trac.osgeo.org/gdal/ticket/5681
>     > >     - https://trac.osgeo.org/gdal/ticket/5705
>     > >     - https://trac.osgeo.org/gdal/ticket/6185 - Tanuj
>     > >     - https://trac.osgeo.org/gdal/ticket/6222
>     > >     - https://trac.osgeo.org/gdal/ticket/6246
>     > >     - https://trac.osgeo.org/gdal/ticket/6304
>     > >     - https://trac.osgeo.org/gdal/ticket/6316
>     > >     - https://trac.osgeo.org/gdal/ticket/6385
>     > >     I checked tickets already get by students. It's good to
>     discuss
>     > >     with community how you plan to fix the tickets before start
>     > >     coding. Also, choose tickets carefully, we need students
>     with good
>     > >     skills, so the ticket should show your potential. Some of you
>     > >     already choose another tickets, and this is normal too,
>     but they
>     > >     need to be discussed too. For example the ticket
>     > > https://trac.osgeo.org/gdal/ticket/6294 is rather controversial.
>     > >     3. We need to see which ideas each of student choose, and
>     what is
>     > >     a plan how to release them. You need some discussion with the
>     > >     community what is best way or some directions to do it.
>     This is
>     > >     not spoil of the time as your ideas come as background for
>     your
>     > >     project announces.
>     > >     It'll be nice have more details for some ideas from list
>     > > https://trac.osgeo.org/gdal/wiki/SummerOfCode. The ideas #7,8,9
>     > >     are very briefly.
>     Spatialys - Geospatial professional services
>     http://www.spatialys.com
Best regards,
     Dmitry
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160314/92e823e5/attachment-0001.html>
