[gdal-dev] New config option for date/time output
Joaquim Luis jluis at ualg.pt
Tue Mar 15 05:08:03 PDT 2016
GMT uses "yyy-mm-ddT[hh:mm:ss] (Gregorian) or yyyy-Www-ddT[hh:mm:ss] (ISO)"
http://gmt.soest.hawaii.edu/doc/latest/gmt.conf.html#calendar-time-parameters
It would be nice to use the same.
Joaquim
> Folks,
> The OGRFeature::GetFieldAsString returns date/time fields formatted in
> non-standard way. For example date is output as "year/month/day" as more
> usual "year-month-day". This causes problems in many programs.
> I suggest adding a new config option OGR_DATE_FORMAT, which, if set,
> would make the method return date/time formatted according to it. I
> suggest that we use the strftime and its format argument as the target
> for the new option.
> The implementation is complicated a bit when milliseconds and timezones
> are involved since they are not included in the struct tm used by
> strftime. I suggest that we assume seconds are formatted as :\d\d in the
> format and simply add milliseconds (as .\d\d\d) and timezone (as
> [+-]\d\d(:\d\d)), if they exists, after the second.
> Do you think this needs a RFC?
> I'm willing to implement the changes.
> Ari
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
