[gdal-dev] GSoC 2016
Jürgen E. Fischer jef at norbit.de
Wed Mar 16 07:07:44 PDT 2016
Hi Alexander,
On Wed, 16. Mar 2016 at 12:40:39 +0000, Борзых Александр Андреевич wrote:
> Overall idea
> DWG  is very wide-spread format and it seems like there is a lot of requests
> for a good conversion tools from DWG to more common spatial data. I  think
> that current implementations of DWG support are not optimal. For  example
> libdwg (abandoned), libredwg (GPLv3 incompatible with X/MIT).
> There are near 7 versions of DWG format (R13, R14, R2000, R2004, R2007,
> R2010, R2013) with differencies in file organisation, so driver should be
> able to read from and write to all of them.
There's also libdxfrw that supports these.  It's what we will use to do a
DWG/DXF import in QGIS.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160316/ab062da4/attachment.sig>
