[gdal-dev] Building GDAL 2.0.0 without ogr on Linux fails
Dmitry Baryshnikov bishop.dev at gmail.com
Thu Mar 17 10:55:18 PDT 2016
Hi Kurt,
I think, that it's time to do this.
Best regards,
     Dmitry
17.03.2016 19:19, Kurt Schwehr пишет:
> I propose that we remove --without-ogr and OGR_ENABLED.  Happy to hear
> arguments for the contrary.  I commented here:
> https://trac.osgeo.org/gdal/ticket/6117
> On Tue, Jun 23, 2015 at 9:14 AM, Even Rouault
> <even.rouault at spatialys.com <mailto:even.rouault at spatialys.com>> wrote:
>     Kor,
>     I'm half surprised this ended up being broken. At the time of
>     https://trac.osgeo.org/gdal/wiki/rfc46_gdal_ogr_unification, it
>     still worked
>     apparently but I might have accidentaly broken it later.
>     Anyway I was wondering if it was worth fixing that? as it might be
>     a continuing
>     maintenance pain... This was something I actually considered
>     during RFC 46 (I
>     mean dropping support for --without-ogr).
>     Even
>     > Dear all,
>     > I may have found an issue in the build scripts of gdal 2.0.0.
>     Building
>     > gdal without ogr on Linux fails on my machine:
>     > ./configure --without-ogr
>     > make -j8
>     > I attached the output of configure and copied the snippets from the
>     > build output detailing the errors below.
>     > When I change --without-ogr into --with-ogr, the build succeeds.
>     > Maybe something OGR-ish is building while it shouldn't(?).
>     > Best regards,
>     > Kor de Jong
>     > libtool: compile:  /opt/gcc-4.9/bin/g++ -I/tmp/blah/gdal-2.0.0/port
>     > -I/tmp/blah/gdal-2.0.0/gcore -I/tmp/blah/gdal-2.0.0/alg
>     > -I/tmp/blah/gdal-2.0.0/ogr
>     -I/tmp/blah/gdal-2.0.0/ogr/ogrsf_frmts -g -O2
>     > -Wall -I/tmp/blah/gdal-2.0.0/port -I/usr/include
>     -DGDAL_COMPILATION -c
>     > mffdataset.cpp -o ../o/mffdataset.o >/dev/null 2>&1
>     > ogrutils.cpp: In function ‘int OGRGeneralCmdLineProcessor(int,
>     char***,
>     > int)’:
>     > ogrutils.cpp:526:60: error: ‘GDAL_OF_VECTOR’ was not declared in
>     this scope
>     >       return GDALGeneralCmdLineProcessor( nArgc, ppapszArgv,
>     > GDAL_OF_VECTOR );
>     > ogrutils.cpp:526:75: error: ‘GDALGeneralCmdLineProcessor’ was not
>     > declared in this scope
>     > GDAL_OF_VECTOR );
>     > ogrutils.cpp:527:1: warning: control reaches end of non-void
>     function
>     > [-Wreturn-type]
>     > make[1]: *** [ogrutils.lo] Error 1
>     > make[1]: *** Waiting for unfinished jobs....
>     > pdfwritabledataset.cpp: In member function ‘virtual OGRErr
>     > PDFWritableVectorDataset::SyncToDisk()’:
>     > pdfwritabledataset.cpp:307:17: error: ‘class GDALPDFWriter’ has no
>     > member named ‘WriteOGRLayer’
>     >           oWriter.WriteOGRLayer((OGRDataSourceH)this,
>     > make[2]: *** [../o/pdfwritabledataset.lo] Error 1
>     > make[2]: *** Waiting for unfinished jobs....
>     > make[1]: *** [pdf-install-obj] Error 2
>     > make: *** [frmts-target] Error 2
>     Spatialys - Geospatial professional services
>     http://www.spatialys.com
>     _______________________________________________
>     gdal-dev mailing list
>     gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160317/7ff88bff/attachment-0001.html>
