[gdal-dev] Building GDAL 2.0.0 without ogr on Linux fails
Kurt Schwehr schwehr at gmail.com
Sun Mar 20 11:56:16 PDT 2016
I didn't see any objections, so I'm going to go ahead and start removing
the option and the #if cpp stuff.
On Thu, Mar 17, 2016 at 10:55 AM, Dmitry Baryshnikov <bishop.dev at gmail.com>
wrote:
> Hi Kurt,
> I think, that it's time to do this.
> Best regards,
>     Dmitry
> 17.03.2016 19:19, Kurt Schwehr пишет:
> I propose that we remove --without-ogr and OGR_ENABLED.  Happy to hear
> arguments for the contrary.  I commented here:
> https://trac.osgeo.org/gdal/ticket/6117
> On Tue, Jun 23, 2015 at 9:14 AM, Even Rouault <even.rouault at spatialys.com>
> wrote:
>> Kor,
>> I'm half surprised this ended up being broken. At the time of
>> https://trac.osgeo.org/gdal/wiki/rfc46_gdal_ogr_unification, it still
>> worked
>> apparently but I might have accidentaly broken it later.
>> Anyway I was wondering if it was worth fixing that? as it might be a
>> continuing
>> maintenance pain... This was something I actually considered during RFC
>> 46 (I
>> mean dropping support for --without-ogr).
>> Even
>> > Dear all,
>> > I may have found an issue in the build scripts of gdal 2.0.0. Building
>> > gdal without ogr on Linux fails on my machine:
>> > ./configure --without-ogr
>> > make -j8
>> > I attached the output of configure and copied the snippets from the
>> > build output detailing the errors below.
>> > When I change --without-ogr into --with-ogr, the build succeeds.
>> > Maybe something OGR-ish is building while it shouldn't(?).
>> > Best regards,
>> > Kor de Jong
>> > libtool: compile:  /opt/gcc-4.9/bin/g++ -I/tmp/blah/gdal-2.0.0/port
>> > -I/tmp/blah/gdal-2.0.0/gcore -I/tmp/blah/gdal-2.0.0/alg
>> > -I/tmp/blah/gdal-2.0.0/ogr -I/tmp/blah/gdal-2.0.0/ogr/ogrsf_frmts -g -O2
>> > -Wall -I/tmp/blah/gdal-2.0.0/port -I/usr/include -DGDAL_COMPILATION -c
>> > mffdataset.cpp -o ../o/mffdataset.o >/dev/null 2>&1
>> > ogrutils.cpp: In function ‘int OGRGeneralCmdLineProcessor(int, char***,
>> > int)’:
>> > ogrutils.cpp:526:60: error: ‘GDAL_OF_VECTOR’ was not declared in this
>> scope
>> >       return GDALGeneralCmdLineProcessor( nArgc, ppapszArgv,
>> > GDAL_OF_VECTOR );
>> > ogrutils.cpp:526:75: error: ‘GDALGeneralCmdLineProcessor’ was not
>> > declared in this scope
>> > GDAL_OF_VECTOR );
>> > ogrutils.cpp:527:1: warning: control reaches end of non-void function
>> > [-Wreturn-type]
>> > make[1]: *** [ogrutils.lo] Error 1
>> > make[1]: *** Waiting for unfinished jobs....
>> > pdfwritabledataset.cpp: In member function ‘virtual OGRErr
>> > PDFWritableVectorDataset::SyncToDisk()’:
>> > pdfwritabledataset.cpp:307:17: error: ‘class GDALPDFWriter’ has no
>> > member named ‘WriteOGRLayer’
>> >           oWriter.WriteOGRLayer((OGRDataSourceH)this,
>> > make[2]: *** [../o/pdfwritabledataset.lo] Error 1
>> > make[2]: *** Waiting for unfinished jobs....
>> > make[1]: *** [pdf-install-obj] Error 2
>> > make: *** [frmts-target] Error 2
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://schwehr.org
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/gdal-dev
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160320/73e2e32d/attachment-0001.html>
