[gdal-dev] S57 conversion
Giorgio Ghiggini gghiggini at gec-it.com
Thu Mar 24 08:38:49 PDT 2016
Hello,
I am trying to use the ogr2ogr to convert an S57 file (IENC) to a different
format but I am having several problems.
I tried converting to ESRI Shapefile but the object with code 17004 (dismar)
is not converted.
I tried then converting to SQlite and the 17004 is converted as generic, but
not all its attributes are converted.
I checked into the "gdal_data" folder and found several csv files to manage
various S57 objects/attributes catalogs.
I see also the IW (Inland water) is present and it seems correct, including
all my object and attribute codes.
Any suggestion ?
Thanks for your help,
Best regards.
Giorgio
Giorgio Ghiggini
GEC s.r.l.
Via Monte Matanna 1/C
55049 Viareggio (LU)
Italy
P.Iva: 02412390466
cell.: +39 331 141 9315
email: gghiggini at gec-it.com
skype: ghigio2000
www.gec-it.com
 <http://www.globalterramaps.com/> www.globalterramaps.com
 <http://www.globalaquamaps.com/> www.globalaquamaps.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160324/8c9571b3/attachment.html>
