[gdal-dev] C++ template functions with raster bands
Even Rouault even.rouault at spatialys.com
Tue Mar 29 10:48:14 PDT 2016
Le mardi 29 mars 2016 17:35:26, Ari Jolma a écrit :
> I want to write template functions like this:
> template<typename cell_type>
> void map(GDALRasterBand *b, mapper<cell_type> *mapper) {
> This function would map the cell values of a band to new ones using some
> logic that is coded within the mapper object (and the logic depends on
> the cell_type).
> I would like to catch errors which are due to mismatch between the band
> data type and the template cell_type. So far I've discovered this:
>      band_wrapper band = band_initialize(b);
>      if (band.info.size_of_data_type != sizeof(cell_type))
>          goto fail_because_of_data_type_mismatch;
> but it is not bullet proof since data types can have an equal size but
> be different. The band_initialize contains a switch statement, which
> sets the info element of the band wrapper.
> Are there other ways to solve this problem? I could build long switch
> statements but it is not very appealing. And it gets messy when there is
> more than one band.
Perhaps by using C++ traits like this :
#include <gdal.h>
template <typename T> struct GetGDALDataTypeTraits
    static const GDALDataType datatype;
template<> struct GetGDALDataTypeTraits<unsigned char>
    static const GDALDataType datatype = GDT_Byte;
template<> struct GetGDALDataTypeTraits<unsigned short>
    static const GDALDataType datatype = GDT_UInt16;
template <typename T> static GDALDataType GetGDALDataType()
  return GetGDALDataTypeTraits<T>::datatype;
#include <iostream>
int main(int argc, char* argv[])
  std::cout << "type unsigned char: " << GetGDALDataType<unsigned char>() << std::endl;
  std::cout << "type unsigned short: " << GetGDALDataType<unsigned short>() << std::endl;
  // Link time error
  //std::cout << "type double: " << GetGDALDataType<double>() << std::endl;
  return 0;
> Ari
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
