[gdal-dev] compile error on windows
Joaquim Luis jluis at ualg.pt
Sun May 1 11:37:20 PDT 2016
If you want to protect your hair don't try to build HDF5.8.12 (and probably some other versions around this one) it will crash a couple times under VS14 and will error at the middle of build with a
timezone variable not found (or similar)
5.10.0 builds fine but the HDF page has worry message saying files build with 5.10 may not be read with 5.8
Joaquim
Sent from my iDedo
No dia 30/04/2016, às 18:15, Jeff McKenna <jmckenna at gatewaygeomatics.com> escreveu:
>> On 2016-04-29 5:17 PM, Ryan Grout wrote:
>> Hello,
>> I'm attempting to build GDAL for windows using Visual Studio 2008.
>> I've included the output of the build failure below.
>> I don't see anything wrong with the linking command (hdf5 library is
>> there).  I've double checked the exported symbols of hdf5.lib and it
>> definitely exports the symbols that gdal complains it can't find.
>> I get this failure on Windows 10 with Visual Studio 2008 and gdal 2.0.0
>> through 2.1.0 RC4.  I suspect it might have something to do with HDF
>> 1.8.16 (since the problem only manifested itself since updating HDF5).
>> Searching this mailing list, I couldn't find similar failures.  Any help
>> would be appreciated.
> Compiling HDF5, HDF4, and NetCDF and making them work with GDAL on Windows is quite a dance.  Be ready to lose hair and what hair you'll have will turn grey.  Then once you think you're in the clear, you try compiling it all on x64 and well, a whole new ballgame of errors.
> I know I've ran into problems compiling this in years past for the MS4W community (http://ms4w.com); there are just so many items to be aware of.  Over the years I've tried to record my notes at:
>  https://trac.osgeo.org/gdal/wiki/HDF
> It would be great if you too could record your notes and 'gotchyas' there.  Anything is a help.
> I'm working on a new build for the MS4W community with the new 2015 compiler, which seems to work better managing these 4 libraries (huge knock on wood!).
> In terms of building HDF5, one of the important notes is during cmake be sure to set "-DBUILD_SHARED_LIBS:BOOL:ON"  I'm not sure if that helps you case or not.
> All this to say, you're not alone in this battle! :)
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
