[gdal-dev] How to add more than one column to a shapefile using ogrinfo
andy aborruso at gmail.com
Sun May 1 13:37:24 PDT 2016
Hi Even,
On 1 May 2016 at 22:28, Even Rouault <even.rouault at spatialys.com> wrote:
> Because it is not implemented... OGR SQL has many implementation
> limitations.
> What is supported is documented here : http://gdal.org/ogr_sql.html
thank you very much. I had read that page, but stupidly I did not think
that "ALTER TABLE tablename ADD [COLUMN] columnname columntype" meant
strictly that I could only use it in this way.
My wrong intepretion was that I could use "alter table add" SQL command
and its variations. But it's only on my my mind.
Thank you again
 Andrea Borruso
website: http://blog.spaziogis.it
38° 7' 48" N, 13° 21' 9" E, EPSG:4326
"cercare e saper riconoscere chi e cosa,
 in mezzo all’inferno, non è inferno,
e farlo durare, e dargli spazio"
Italo Calvino
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160501/fe996119/attachment.html>
