[gdal-dev] Questions about MBTiles write support @ GDAL 2.1 RC4
Even Rouault even.rouault at spatialys.com
Mon May 2 04:39:29 PDT 2016
Le lundi 02 mai 2016 13:03:34, gunnarblom a écrit :
> Even Rouault-2 wrote
> >> 1) When creating a MBTiles file, only one layer is written. Can you use
> >> GDAL to populate other layers?
> > I'm not sure what you call "layer". AFAIK MBTiles files do not have a
> > concept
> > of storing tiles for different layers. (you could use GeoPackage for
> > that)
> I'm talking about zoom layers.
Ah ok, you can generate overviews/zoom layers with gdaladdo /
GDALBuildOverviews().
> >> 2) Can you choose to create 512*512px tiles
> >> instead of the 256*256px default? Would increase quality on retina
> >> devices.
> > It is true that the spec doesn't say anyting about tile size, but are
> > there
> > MBTiles files with tiles not 256x256 ? This isn't supported by the
> > driver. On
> > writing this shouldn't be a big problem. On reading this might be a bit
> > more
> > tricky as you could potentially have a mix of tiles of different sizes !
> I guess the MBTiles format could have metadata about what resolution the
> tiles are in.
It could, but this isn't standardized
> But also the readers/viewers should just draw the tiles in
> their correct place and shouldn't be dependent on what resolution they
> have? Isn't that how it works with a regular TMS folder structure anyway?
For viewers, yes. For the reader side of the GDAL driver, this is a bit
difference as it needs to determine a fixed resolution per zoom layer.
> http://osgeo-org.1560.x6.nabble.com/gdal-dev-Questions-about-MBTiles-write
> -support-GDAL-2-1-RC4-tp5263684p5263887.html Sent from the GDAL - Dev
> mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
