[gdal-dev] IReadBlock fails on alpha band, GDAL 2
Even Rouault even.rouault at spatialys.com
Mon May 2 04:56:39 PDT 2016
> Are there any other problems that you anticipate with using this
> configuration? I see RGBA JPEG-in-TIFF quite often...
I'd expect libtiff based software to generally work fine with that (with the
exception of this bug of course, which is a rather convoluted way of using
libtiff and the JPEG driver)
I see that support in libtiff to generate such images is relatively "recent" (4
years ago) : https://trac.osgeo.org/gdal/ticket/4732
> > Fixed per https://trac.osgeo.org/gdal/ticket/6493
> > Use of implicit overviews can be disabled by defining the config option
> > GTIFF_IMPLICIT_JPEG_OVR=NO
> I can confirm that setting GTIFF_IMPLICIT_JPEG_OVR works and this will
> suffice as a workaround until the next GDAL release. Thanks, Even!
http://www.spatialys.com
