[gdal-dev] gdal_translate a VRT built on top of GeoTIFFs with NaN
Daniele Romagnoli daniele.romagnoli at geo-solutions.it
Mon May 2 06:16:30 PDT 2016
Hi Even,
The produced GeoTIFF doesn't contain any nodata metadata/flag/TAG.
It simply has "NaN" pixels. QuantumGIS report those pixels as "nan" and
OpenEV report them as 1.#QNAN so I think they are properly "recognized" as
NaN.
I'm wondering if the GDAL utilities explicitly look for some metadata/flag
(as the "nodata value" in your previous ascii based sample) to do noData
checks or if it's also able to recognize a NaN "binary" value inside the
pixels.
What do you think about it?
Cheers,
Daniele
On Mon, May 2, 2016 at 2:52 PM, Daniele Romagnoli <
daniele.romagnoli at geo-solutions.it> wrote:
> Hi Even.
> Thanks for the feedback.
> Sorry... I'm using GDAL 1.11.3.
> I'm going to double check to make sure I didn't make any mistake.
> I'll let you know.
> Cheers,
> Daniele
> On Mon, May 2, 2016 at 2:49 PM, Even Rouault <even.rouault at spatialys.com>
> wrote:
>> Le lundi 02 mai 2016 14:37:39, Daniele Romagnoli a écrit :
>> > Hi List,
>> > I have a reprojectiion tool which creates GeoTIFFs with NoData = NaN.
>> > I'm creating couple of GeoTIFFs with partially overlapping areas where
>> > GeoTIFF1 has NaNs in a region and GeoTIFF2 has proper values in the same
>> > overlapping region and viceversa (GeoTIFF2 has some NaN area while
>> GeoTIFF1
>> > has valid pixels for same area).
>> > I have built a VRT on top of them and then translated into a single
>> > GeoTIFF. However, the result has NaN in those regions.
>> > I was hoping that the area containing NaNs would have been ignored
>> instead,
>> > in favor of proper values from the other file.
>> > Is there any flag, properties or suggestions to make it working?
>> > If I configure the reprojection tool to write NoData = -9999 and then
>> use
>> > gdalbuildvrt -srcnodata -9999, things are working fine.
>> > So I'm just wondering if the same can be achieved dealing with NaN
>> instead
>> > of custom values.
>> Daniele,
>> You didn't mention which GDAL version you use. It is possible that
>> support for
>> NaN as a nodata value in gdalbuildvrt & the VRT driver was fixed at some
>> point.
>> From a quick test with trunk, it works  (works with 1.11 branch as well):
>> $ cat in1.asc
>> ncols        3
>> nrows        3
>> xllcorner    440720.000000000000
>> yllcorner    3750120.000000000000
>> cellsize     60.000000000000
>> NODATA_value    nan
>>  1.0 1.0 1.0
>>  1.0 nan 1.0
>>  1.0 1.0 1.0
>> $ cat in2.asc
>> ncols        3
>> nrows        3
>> NODATA_value    nan
>>  nan nan nan
>>  nan 2.0 nan
>>  nan nan nan
>> $ gdalbuildvrt nan.vrt in1.asc in2.asc
>> $ gdal_translate nan.vrt /vsistdout/ -of aaigrid
>> ncols        3
>> nrows        3
>> NODATA_value    nan
>>       1      1      1
>>       1      2      1
>>       1      1      1
>> Even
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Daniele Romagnoli
> Senior Software Engineer
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:      +39 0584 1660272
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
GeoSolutions S.A.S.
Italy
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160502/9012c82f/attachment.html>
