[gdal-dev] gdal_translate a VRT built on top of GeoTIFFs with NaN
Even Rouault even.rouault at spatialys.com
Mon May 2 06:58:45 PDT 2016
Le lundi 02 mai 2016 15:43:42, Daniele Romagnoli a écrit :
> Cool!
> Do you think this capability will be backported to 1.11 series too?
Possibly if you file a ticket about that.
> Thanks for your assistance.
> Cheers,
> Daniele
> On Mon, May 2, 2016 at 3:42 PM, Even Rouault <even.rouault at spatialys.com>
> wrote:
> > Le lundi 02 mai 2016 15:37:58, Daniele Romagnoli a écrit :
> > > On Mon, May 2, 2016 at 3:27 PM, Even Rouault
> > > wrote:
> > > > Le lundi 02 mai 2016 15:16:30, Daniele Romagnoli a écrit :
> > > > > Hi Even,
> > > > > The produced GeoTIFF doesn't contain any nodata metadata/flag/TAG.
> > > > > It simply has "NaN" pixels. QuantumGIS report those pixels as "nan"
> > and
> > > > > OpenEV report them as 1.#QNAN so I think they are properly
> > "recognized"
> > > > as
> > > > > NaN.
> > > > > I'm wondering if the GDAL utilities explicitly look for some
> > > > metadata/flag
> > > > > (as the "nodata value" in your previous ascii based sample) to do
> > > > > noData checks or if it's also able to recognize a NaN "binary"
> > > > > value inside the pixels.
> > > > Yes, the NaN value must be explicitly set as the nodata property of
> > > > the geotiff
> > > > file so that gdalbuildvrt can recognize it as the nodata value
> > (similarly
> > > > to
> > > > other nodata value)
> > > > You can do this with gdal_translate -a_nodata nan (or gdal_edit.py
> > > > -a_nodata
> > > > nan)
> > > Ok. Thanks.
> > > I was trying to add it with "gdalbuildvrt -srcnodata nan" to avoid an
> > > intermediate step between my geotiff and the VRT but I was getting:
> > > ERROR 5: Invalid -srcnodata value
> > > Therefore, I had to edit the VRT by replacing the
> > > <ComplexSource><NODATA>-9999</NODATA></ComplexSource> with "nan"
> > > instead
> > of
> > > "-9999".
> > > Do you know if there is any chance to let the -srcnodata parameter
> > accept a
> > > String like "nan"?
> > Yes, this is available in the fresh new 2.1.0:
> >  * gdalbuildvrt: accept nan as value for -srcnodata and -vrtnodata
> > > Cheers,
> > > Daniele
> > > > > What do you think about it?
> > > > > Cheers,
> > > > > Daniele
> > > > > On Mon, May 2, 2016 at 2:52 PM, Daniele Romagnoli <
> > > > > daniele.romagnoli at geo-solutions.it> wrote:
> > > > > > Hi Even.
> > > > > > Thanks for the feedback.
> > > > > > Sorry... I'm using GDAL 1.11.3.
> > > > > > I'm going to double check to make sure I didn't make any mistake.
> > > > > > I'll let you know.
> > > > > > Cheers,
> > > > > > Daniele
> > > > > > On Mon, May 2, 2016 at 2:49 PM, Even Rouault <
> > > > > > wrote:
> > > > > >> Le lundi 02 mai 2016 14:37:39, Daniele Romagnoli a écrit :
> > > > > >> > Hi List,
> > > > > >> > I have a reprojectiion tool which creates GeoTIFFs with NoData
> > > > NaN.
> > > > > >> > I'm creating couple of GeoTIFFs with partially overlapping
> > > > > >> > areas
> > > > where
> > > > > >> > GeoTIFF1 has NaNs in a region and GeoTIFF2 has proper values
> > > > > >> > in the same overlapping region and viceversa (GeoTIFF2 has
> > > > > >> > some NaN area while
> > > > > >> GeoTIFF1
> > > > > >> > has valid pixels for same area).
> > > > > >> > I have built a VRT on top of them and then translated into a
> > > > > >> > single GeoTIFF. However, the result has NaN in those regions.
> > > > > >> > I was hoping that the area containing NaNs would have been
> > ignored
> > > > > >> instead,
> > > > > >> > in favor of proper values from the other file.
> > > > > >> > Is there any flag, properties or suggestions to make it
> > > > > >> > working?
> > > > > >> > If I configure the reprojection tool to write NoData = -9999
> > > > > >> > and
> > > > then
> > > > > >> use
> > > > > >> > gdalbuildvrt -srcnodata -9999, things are working fine.
> > > > > >> > So I'm just wondering if the same can be achieved dealing with
> > NaN
> > > > > >> instead
> > > > > >> > of custom values.
> > > > > >> Daniele,
> > > > > >> You didn't mention which GDAL version you use. It is possible
> > > > > >> that support for
> > > > > >> NaN as a nodata value in gdalbuildvrt & the VRT driver was fixed
> > at
> > > > some
> > > > > >> point.
> > > > > >> From a quick test with trunk, it works  (works with 1.11 branch
> > > > > >> as well):
> > > > > >> $ cat in1.asc
> > > > > >> ncols        3
> > > > > >> nrows        3
> > > > > >> xllcorner    440720.000000000000
> > > > > >> yllcorner    3750120.000000000000
> > > > > >> cellsize     60.000000000000
> > > > > >> NODATA_value    nan
> > > > > >>  1.0 1.0 1.0
> > > > > >>  1.0 nan 1.0
> > > > > >>  1.0 1.0 1.0
> > > > > >> $ cat in2.asc
> > > > > >> ncols        3
> > > > > >> nrows        3
> > > > > >> NODATA_value    nan
> > > > > >>  nan nan nan
> > > > > >>  nan 2.0 nan
> > > > > >>  nan nan nan
> > > > > >> $ gdalbuildvrt nan.vrt in1.asc in2.asc
> > > > > >> $ gdal_translate nan.vrt /vsistdout/ -of aaigrid
> > > > > >> ncols        3
> > > > > >> nrows        3
> > > > > >> NODATA_value    nan
> > > > > >>       1      1      1
> > > > > >>       1      2      1
> > > > > >>       1      1      1
> > > > > >> Even
> > > > > >> Spatialys - Geospatial professional services
> > > > > >> http://www.spatialys.com
> > > > > > GeoServer Professional Services from the experts! Visit
> > > > > > http://goo.gl/it488V for more information.
> > > > > > Ing. Daniele Romagnoli
> > > > > > Senior Software Engineer
> > > > > > GeoSolutions S.A.S.
> > > > > > Via di Montramito 3/A
> > > > > > 55054  Massarosa (LU)
> > > > > > Italy
> > > > > > phone: +39 0584 962313
> > > > > > fax:      +39 0584 1660272
> > > > > > http://www.geo-solutions.it
> > > > > > http://twitter.com/geosolutions_it
> > > > > > *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> > > > > > Le informazioni contenute in questo messaggio di posta
> > > > > > elettronica e/o nel/i file/s allegato/i sono da considerarsi
> > > > > > strettamente riservate. Il loro utilizzo è consentito
> > > > > > esclusivamente al destinatario del
> > > > messaggio,
> > > > > > per le finalità indicate nel messaggio stesso. Qualora riceviate
> > > > > > questo messaggio senza esserne il destinatario, Vi preghiamo
> > > > > > cortesemente di darcene notizia via e-mail e di procedere alla
> > > > > > distruzione del
> > > > messaggio
> > > > > > stesso, cancellandolo dal Vostro sistema. Conservare il messaggio
> > > > stesso,
> > > > > > divulgarlo anche in parte, distribuirlo ad altri soggetti,
> > copiarlo,
> > > > > > od utilizzarlo per finalità diverse, costituisce comportamento
> > > > > > contrario
> > > > ai
> > > > > > principi dettati dal D.Lgs. 196/2003.
> > > > > > The information in this message and/or attachments, is intended
> > > > > > solely for the attention and use of the named addressee(s) and
> > > > > > may be confidential or proprietary in nature or covered by the
> > > > > > provisions of privacy act (Legislative Decree June, 30 2003,
> > > > > > no.196 - Italy's New
> > > > Data
> > > > > > Protection Code).Any use not in accord with its purpose, any
> > > > disclosure,
> > > > > > reproduction, copying, distribution, or either dissemination,
> > either
> > > > > > whole or partial, is strictly forbidden except previous formal
> > > > > > approval of the named
> > > > > > addressee(s). If you are not the intended recipient, please
> > > > > > contact immediately the sender by telephone, fax or e-mail and
> > > > > > delete the information in this message that has been received in
> > > > > > error. The sender does not give any warranty or accept liability
> > > > > > as the content, accuracy or completeness of sent messages and
> > > > > > accepts no responsibility  for changes made after they were sent
> > > > > > or for other risks which arise as a result of e-mail
> > > > > > transmission, viruses, etc.
