[gdal-dev] GDAL 2.0.2 & gpkg woes
Alan Stewart astewart at terragotech.com
Mon May 2 12:12:29 PDT 2016
Unfortunately, makes no difference, with my application code or ogr2ogr. I also tested the new libspatialite-4.2.0a DLL against my old GDAL build. Works fine.
Alan Stewart
Senior Software Engineer
TerraGo Technologies
3200 Windy Hill Road, Suite 1550W
Atlanta, GA 30339 USA
O.  +1 678.391.9615
www.terragotech.com
-----Original Message-----
From: Even Rouault [mailto:even.rouault at spatialys.com]
Sent: Saturday, April 30, 2016 11:00 AM
To: gdal-dev at lists.osgeo.org
Cc: Alan Stewart
Subject: Re: [gdal-dev] GDAL 2.0.2 & gpkg woes
On Friday 29 April 2016 14:07:52 Alan Stewart wrote:
> My debug build of ogr2ogr.exe fails in exactly the same way as my
> application code fails. Apparently there's some difference in how the
> new GPKG code uses spatialite or expects spatialite to be built? The
> same libspatialite DLL works with our GDAL 1.11.0 DLL, but fails with
> the new GDAL 2.0.2 DLL.
Alan,
Never heard of similar issues. But you could probably try to upgrade to the latest version of sqlite in the 3.8.X series. And/or upgrade your spatialite version to the latest stable 4.3.0a.
Might be possible that the changes between GDAL 1.11 and 2.0 have triggered an integration issue with one of the sqlite/spatialite versions you use.
Even
> Alan Stewart
> O.  +1 678.391.9615
> www.terragotech.com
> gdal-dev mailing list
Spatialys - Geospatial professional services http://www.spatialys.com
