[gdal-dev] compile error on windows
Even Rouault even.rouault at spatialys.com
Tue May 3 00:54:58 PDT 2016
Le lundi 02 mai 2016 23:21:04, Ryan Grout a écrit :
> Thanks, again Christoph.  You're a lifesaver.
> For the benefit of the gdal-dev list.
> Applying the below patch to GDAL fixed my build issues with HDF5 1.8.16
> -- diff --git frmts/hdf5/makefile.vc frmts/hdf5/makefile.vc
> index e2e695d..02f006f 100644
> --- frmts/hdf5/makefile.vc
> +++ frmts/hdf5/makefile.vc
> @@ -7,7 +7,7 @@ OBJ        =    hdf5dataset.obj  hdf5imagedataset.obj \
>  PLUGIN_DLL     =    gdal_HDF5.dll
> -EXTRAFLAGS     =     -I$(HDF5_DIR)\include -DWIN32 -D_HDF5USEDLL_
> +EXTRAFLAGS     =     -I$(HDF5_DIR)\include -DWIN32
> -DH5_BUILT_AS_DYNAMIC_LIB
Jeff,
does the above match your experience ? We could probably define both
_HDF5USEDLL_ and H5_BUILT_AS_DYNAMIC_LIB to address different versions.
I see in https://www.hdfgroup.org/windows/faq.html that _HDF5USEDLL_ is still
advised.
Ryan,
could you try with both  -D_HDF5USEDLL_ and  -DH5_BUILT_AS_DYNAMIC_LIB defined
? (make sure to clean the frmts/hdf5 directory before rebuilding)
Even
http://www.spatialys.com
