[gdal-dev] compile error on windows
Jeff McKenna jmckenna at gatewaygeomatics.com
Tue May 3 10:57:45 PDT 2016
I'm also very ok with changing the default to set
H5_BUILT_AS_DYNAMIC_LIB only - I'll just edit the makefile before
building.  Not an issue for me.
Since no one is recording these notes from this long discussion in the
buildhints wiki, I'm +1 to change to this new setting in makefile.vc;
then I'll make a note on the buildhints wiki and make sure the MS4W
process is updated.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2016-05-03 2:42 PM, Jeff McKenna wrote:
> On 2016-05-03 1:36 PM, Even Rouault wrote:
>> If you have the opportunity, it would be good if you could check if
>> defining
>> both _HDF5USEDLL_ and H5_BUILT_AS_DYNAMIC_LIB doesn't affect
>> negatively your
>> builds. Ideally, we'd like to have a default set of compilation flags
>> that
>> works out of the box for (almost) everybody.
> It will depend how HDF5 was compiled (the cmake settings).  For example,
> I build the static lib of HDF5, and therefore in GDAL's nmake.opt I
> point to "libhdf5.lib".  In my case I therefore do not need to set
> If I try to set both _HDF5USEDLL_ and H5_BUILT_AS_DYNAMIC_LIB I get 61
> unresolved symbols in the linker.
> Now are you understanding my grey hair comment Even? :)
> I feel these notes are important to document in the buildhints wiki.
> -jeff
