[gdal-dev] compile error on windows
Jeff McKenna jmckenna at gatewaygeomatics.com
Tue May 3 11:21:14 PDT 2016
On 2016-05-03 3:11 PM, Even Rouault wrote:
> Le mardi 03 mai 2016 19:57:45, Jeff McKenna a écrit :
>> I'm also very ok with changing the default to set
>> H5_BUILT_AS_DYNAMIC_LIB only - I'll just edit the makefile before
>> building.  Not an issue for me.
> I'm not keen to modify things without a clear understanding of what is
> required in which context.
Well if I go back and build the dynamic HDf5 lib, and then set
H5_BUILT_AS_DYNAMIC_LIB, then of course my resulting gdal.dll is smaller
in size, which I could live with.  So making this the default setting
'going forward' in GDAL makes sense.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
