[gdal-dev] Geotiff FillEmptyTiles with no data value?
jramm jamessramm at gmail.com
Tue May 3 11:23:49 PDT 2016
Hi
When writing geotiffs, if I dont write blocks they will automatically be
filled on close by the FillEmptyTiles.
It appears that this will only fill with zeros - is it possible to make it
fill with the no data value instead?
This is potentially a huge time saver when processing a large, fairly sparse
geotiff using python as relying on gdal to fill in 'null' blocks appears far
quicker than calling the python write method.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geotiff-FillEmptyTiles-with-no-data-value-tp5264310.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
