[gdal-dev] GDAL 2.1 and Norwegian SOSI
Even Rouault even.rouault at spatialys.com
Tue May 3 12:32:31 PDT 2016
Le mardi 03 mai 2016 21:06:14, Blumentrath, Stefan a écrit :
> Dear GDAL-devs,
> I just tried to open a Norwegian SOSI file with ogrinfo from GDAL 2.1dev
> but get: FAILURE:
> Unable to open datasource `./ADM_kommune_2018_Masoy.sos' with the following
> drivers.
> 'ogrinfo --formats' does not list the SOSI driver either. But I am sure I
> did compile with '--with-sosi' and gdal-config --dep-libs lists the
> openfyba libs used for the driver.
Hum, I see this is actually a 2.1.0 regression.
Fix available in https://trac.osgeo.org/gdal/ticket/6500
> So my question is,: were there any changes from 1.11 to 2.x which may
> affect the driver? Any chance someone will make that working again?
> Unfortunately our mapping authority does not seem to be maintaining the
> OpenFYBA lib any more (SOSI version 4.5 not yet supported), so I can
> understand if you are not too keen on fixing the issue (if it is not
> local).
> Thanks for any help.
> Kind regards,
> Stefan
http://www.spatialys.com
