[gdal-dev] Starting a discussion on style and coding guidelines
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu May 5 05:22:03 PDT 2016
On 2016-05-05 9:10 AM, Jeff McKenna wrote:
> On 2016-05-05 5:14 AM, Dmitry Baryshnikov wrote:
>> Hi,
>> I think it's time to go forward and shift to C++11 in i.e. GDAL 2.2 and
>> drop old staff as it was with Windows mobile support, VB, etc.
>> Yes, it may be some regression in ABI, but this is less evil than
>> support lot of ancient compilers.
>> During our work on cmake build system for GDAL I faced that some
>> dependency library needs VC2013SP2 on Windows - i.e liblzma, as it needs
>> C99.
>> We worked around it by including some logic to cmake, that if VC
>> compiler is less than specific version the support of dependent features
>> will be disabled.
>> By the way, the repo with cmake for GDAL is here:
>> https://github.com/nextgis-extra/lib_gdal
>> The ubuntu ppa of libgdal2 build using cmake:
>> https://launchpad.net/~nextgis/+archive/ubuntu/ppa/+packages
>> Windows builds also using cmake: http://nextgis.ru/en/borsch/
> About a month ago I made the hard decision to upgrade my entire MS4W
> build environment from VC 2008 to 2015.  Driving this is that PHP 7 only
> supports 2015.
> The only GDAL dependent library not supported for VC 2015 is FileGDB
> (I've seen an Esri developer state that 2015 SDK will be released with
> their next FileGDB API upgrade).
> MrSID 9.5.1 SDK works well with 2015.
> I didn't try an ECW 5.x SDK, but the old 3.3 SDK works well with 2015.
> Short story is I support future GDAL builds requiring a more recent
> Visual Studio compiler (2013+), as other projects are already doing so.
> For those packagers cringing in the thought of upgrading their whole
> stack: join the club :)
I should also note that for compiling Python 3.5.x VC 2015 is the
supported environment.  Yet another GDAL dependent library that favors
an upgraded compiler on Windows.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
