[gdal-dev] Starting a discussion on style and coding guidelines
Mateusz Loskot mateusz at loskot.net
Fri May 6 07:38:04 PDT 2016
On 6 May 2016 at 16:20, Joaquim Luis <jluis at ualg.pt> wrote:
> On Fri, 06 May 2016 15:00:07 +0100, Even Rouault
> <even.rouault at spatialys.com> wrote:
>>> - ECW SDK 5.2.1: available for VS2010, VS2012, VS2013
>> I got information that the next SDK 5.3 should support VS2012, 2013 and
>> 2015
>> (so no more 2010) + GCC 5
> And one can also build SDK 3.3 with all of those compilers (I did).
I do it too, works well indeed.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
