[gdal-dev] Starting a discussion on style and coding guidelines
Jeff McKenna jmckenna at gatewaygeomatics.com
Fri May 6 07:55:31 PDT 2016
On 2016-05-06 11:38 AM, Mateusz Loskot wrote:
> On 6 May 2016 at 16:20, Joaquim Luis <jluis at ualg.pt> wrote:
>> On Fri, 06 May 2016 15:00:07 +0100, Even Rouault
>> <even.rouault at spatialys.com> wrote:
>>>> - ECW SDK 5.2.1: available for VS2010, VS2012, VS2013
>>> I got information that the next SDK 5.3 should support VS2012, 2013 and
>>> 2015
>>> (so no more 2010) + GCC 5
>> And one can also build SDK 3.3 with all of those compilers (I did).
> I do it too, works well indeed.
same.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
