[gdal-dev] how to write multi-IFD TIFF files ?
fred p mapoubelle22 at gmail.com
Mon May 9 09:28:40 PDT 2016
Sorry for the previous message with a bad subject...
---------- Forwarded message ----------
Date: 2016-05-09 16:26 GMT+00:00
Subject: Re: gdal-dev Digest, Vol 144, Issue 30
To: gdal-dev at lists.osgeo.org
Thanks for confirming what I guessed.
What follows is not directly related to GDAL but someone might have a
solution. So... Using geotifcp I cannot assemble a JPEG-compressed TIFF and
a LZW-compressed TIF keeping these compression modes for both IFD. Tiffcp
can do it (but without georeferencing of course !) whereas geotifcp ouputs
"JPEGLib: Bogus input colorspace". Any idea ?
> Message: 2
> Date: Sun, 8 May 2016 00:19:51 +0200
> From: Even Rouault <even.rouault at spatialys.com>
> Subject: Re: [gdal-dev] how to write multi-IFD TIFF files ?
> Message-ID: <201605080019.51485.even.rouault at spatialys.com>
> Content-Type: Text/Plain;  charset="utf-8"
> Le samedi 07 mai 2016 23:57:18, fred p a écrit :
> > Hello,
> > I am looking for a way to write multi-IFD TIFF files with GDAL (each IFD
> > being JPEG or LZW compressed), for example with gdal_translate or (better
> > if possible) the Python API but without any success.
> > Is it possible anyway ?
> Hi,
> No this is not currently possible in the general case (internal overviews
> are
> implemented as IFD, but flagged as such and not as general purpose IFD).
> Would
> probably not a huge effort to implement, but in the mean time you may use
> GDAL
> to create individual IDF and then use tifcp/geotifcp to assemble them.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160509/c049dbd4/attachment.html>
