[gdal-dev] Starting a discussion on style and coding guidelines
Joaquim Luis jluis at ualg.pt
Mon May 9 09:43:08 PDT 2016
> I like one statement per line because it helps walking through the code
> with gdb; you can see the whole statement that is going to be executed.
Fully agree, and my example respects that.
> I also share the idea that seeing a whole subroutine or a logical part
> at once helps understanding the code.
> Ari
> 09.05.2016, 18:14, Joaquim Luis kirjoitti:
>> Hi,
>> There is one aspect of the coding style that I honestly do not
>> understand. Why continuing to recommend the 80 chars line width? I
>> don't by the readability argument, well on the contrary, if because of
>> it the result is an excess 'verticalization' of the code it becomes
>> much harder to read.
>> I don't know for you guys but when I'm forced to permanently scroll up
>> and down it becomes really much harder to study a code. For me the
>> ideal is that a function holds in a single screen size, but ofc without
>> piling up everything to reach that goal.
>> A little example from gdaldem_lib.cpp (line 240)
>> ****************** Current code *********************************
>>     for ( i = 0; i < 2 && i < nYSize; i++)
>>         if( GDALRasterIO(   hSrcBand,
>>                         GF_Read,
>>                         0, i,
>>                         nXSize, 1,
>>                         pafThreeLineWin + i * nXSize,
>>                         nXSize, 1,
>>                         GDT_Float32,
>>                         0, 0) != CE_None )
>>             eErr = CE_Failure;
>>             goto end;
>> ************ What I think would be reasonable
>>     for (i = 0; i < 2 && i < nYSize; i++) {
>>         if (GDALRasterIO(hSrcBand, GF_Read, 0, i, nXSize, 1,
>> pafThreeLineWin + i * nXSize, nXSize, 1,
>>                          GDT_Float32, 0, 0) != CE_None ) {
>>             eErr = CE_Failure;
>>             goto end;
>> 7 lines instead of 15, and is it less readable (in a text editor, not
>> in a mail client)?
>> Joaquim
>>> On 9 May 2016 at 09:15, Ari Jolma <ari.jolma at gmail.com> wrote:
>>>> 05.05.2016, 01:30, Kurt Schwehr kirjoitti:
>>>> Hi all,
>>>> If you've been watching the timeline on trac, you have probably seen
>>>> a large
>>>> number of cleanup CLs from me.  It's definitely past time to get some
>>>> discussion going on these changes.  If the community likes these, we
>>>> can add
>>>> them to rfc8_devguide.
>>>> It is very minimal right now. Good style guides tend to be quite
>>>> large,
>>>> e.g., https://google.github.io/styleguide/cppguide.html or
>>>> http://geosoft.no/development/cppstyle.html
>>> Good C++ guidelines that fit on a single page is all you need
>>> these days, after Bjarne Stroustrup
>>> https://parasol.tamu.edu/people/bs/622-GP/C++11-style.pdf
>>> Best regards,
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
