[gdal-dev] GDAL error - ImportFromEPSG
Christopher Beddow christopher.beddow at gmail.com
Mon May 16 17:57:50 PDT 2016
Hello!
I'm running Python 2.7.8 [MSC v.1500 32 bit (Intel)] on win32. It is the
package that comes with ArcGIS 10.3. I have the correct GDAL core and
Python bindings installed to match.
I'm having an issue testing ImportFromEPSG() with GDAL.
2
down vote
favorite
I'm currently getting an error when testing ImportFromEPSG() on my GDAL.
    import osr
    testSR = osr.SpatialReference()
    testSR.ImportFromEPSG(4326)
    #this returns value of 6
    print testSR.ExportToPrettyWkt()
    #this returns blank/empty string
I have done:
    'GDAL_DATA' in os.evirons
    #returns TRUE
I also set
    os.environs['GDAL_DATA'] = r'C:\Program Files (x86)\GDAL\gdal-data'
which is where gcs.csv is located.
Any suggestions for fixing this? Could ArcGIS be causing the problems?
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160516/de0f5595/attachment.html>
