[gdal-dev] Creating a GeoPackage with multiple tile raster source in gdal 2.1.0
Even Rouault even.rouault at spatialys.com
Tue May 17 08:19:12 PDT 2016
Le mardi 17 mai 2016 17:08:32, Gane R a écrit :
> Hi all,
> I am using a pre-build version of gdal 2.1.0. I am able to create GeoTIFF
> to GeoPackage using gdal_translate.
> I see from the Geopackage specification I understand that Geopackage can
> have multiple tile sources, If so
> Q1: How to I add a tilesource to an exisiting geopackage from a GeoTIFF ?
> any command line or any workflow sequence will be of great help.
This is documented at http://gdal.org/drv_geopackage_raster.html . See APPEND_SUBDATASET=YES creation option,
possibly combined with RASTER_TABLE.
$ gdal_translate byte1.tif out.gpkg -of GPKG -co RASTER_TABLE=table1
Input file size is 20, 20
0...10...20...30...40...50...60...70...80...90...100 - done.
$ gdal_translate byte2.tif out.gpkg -of GPKG -co APPEND_SUBDATASET=YES -co RASTER_TABLE=table2
> Q2: If a geopackage has multiple Geopackage tile raster, If I wish to
> convert any one to a geotiff how will I do ? Should I used OGR Select layer
> or how ??
$ gdalinfo out.gpkg
Driver: GPKG/GeoPackage
Files: out.gpkg
Size is 512, 512
Coordinate System is `'
Subdatasets:
  SUBDATASET_1_NAME=GPKG:out.gpkg:table1
  SUBDATASET_1_DESC=table1 - table1
  SUBDATASET_2_NAME=GPKG:out.gpkg:table2
  SUBDATASET_2_DESC=table2 - table2
Corner Coordinates:
Upper Left  (    0.0,    0.0)
Lower Left  (    0.0,  512.0)
Upper Right (  512.0,    0.0)
Lower Right (  512.0,  512.0)
Center      (  256.0,  256.0)
$ gdal_translate GPKG:out.gpkg:table1 table1.tif
Even
http://www.spatialys.com
