[gdal-dev] GeoPDF
Luca Delucchi lucadeluge at gmail.com
Wed May 18 23:20:39 PDT 2016
On 18 May 2016 at 18:30, Frank Broniewski <frank.broniewski at gmail.com> wrote:
> Hi Luca,
Hi Frank,
>> I developed a plugin for QGIS to export layers (vector and raster) to
>> geospatial PDF using GDAL library.
>> I'm waiting the authorization from the customer to publish it in the
>> plugin repository.
> this sounds interesting. But your plugin cannot save a map composition with
> legend, neatline and all the other "carto things", can it? That's what I am
> after in the end. But if you have some docs or other info to share, I will
> gladly accept any help ;-)
No, the plugin is not saving the map composition, but you can add
legend and other carto things as extra images.
> Frank
ciao
Luca
www.lucadelu.org
