[gdal-dev] From HDF to Tiff format, and reproject from sinusoidal to WGS84 for MODIS LST and ET data
Joaquim Luis jluis at ualg.pt
Wed May 25 16:25:37 PDT 2016
I don't know if this is related to an issue that I posted here some weeks
ago where the HDF's array metadata is not read by the HDF5 driver (but
this files are not HDF5) but the thing is that I can read it with the GMT
developing version (maybe it works too with official releases version too
but can't test it).
grdinfo
MOD16A2.A2000193.h31v11.105.2013122033833.hdf=gd?HDF4_EOS:EOS_GRID:"MOD16A2.A2000193.h31v11.105.2013122033833.hdf":MOD_Grid_MOD16A2:ET_1km
HDF4_EOS:EOS_GRID:MOD16A2.A2000193.h31v11.105.2013122033833.hdf:MOD_Grid_MOD16A2:ET_1km:
Title: Grid imported via GDAL
Command:
Remark:
Gridline node registration used [Cartesian grid]
Grid file format: gd = Import/export through GDAL
x_min: 14455820.0684 x_max: 15566843.9626 x_inc: 926.625433055 name: x nx:
1200
y_min: -3335388.24628 y_max: -2224364.35205 y_inc: 926.625433056 name: y
ny: 1200
z_min: 0.2 z_max: 3276.6 name: z
scale_factor: 0.1 add_offset: 0 packed z-range: [2,32766]
+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6371007.181 +b=6371007.181 +units=m
+no_defs
And for example extracting the first array.
grdconvert
lixo.grd
PS. Even, I did try to add the methods to the HDF5 driver but stumped on
how to get the info out of the HDF5 file (damn complicated API) so fall
back in GMT to fetch them from the text strings of all metadata. In lack
of better, perhaps the same can be in the GDAL HDF5 driver.
Joaquim
> Hi,
> I'm fairly new to GIS and could use some help converting MODIS LST and
> ET data to TIFF format in WGS84 projection.
> Example files can be obtained here:
> http://e4ftl01.cr.usgs.gov/MOLT/MOD11A1.005/2004.03.31/
> ftp://ftp.ntsg.umt.edu/pub/MODIS/NTSG_Products/MOD16/MOD16A2.105_MERRAGMAO/Y2000/D193/
> I'm haven't been able to figure out how to correctly specify the
> parameters in the gdalwarp step.
> I've posted a GIS-Stack Exchange question here, but haven't gotten any
> replies yet.
> Thanks a lot.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160526/480de77d/attachment.html>
