[gdal-dev] Spatial index to raster VRT
Even Rouault even.rouault at spatialys.com
Thu May 26 08:32:46 PDT 2016
On Thursday 26 May 2016 13:26:38 Jukka Rahkonen wrote:
> Daniel Morissette <dmorissette <at> mapgears.com> writes:
> > On 2016-05-26 8:40 AM, Jukka Rahkonen wrote:
> > > Hi,
> > > Any thoughts about alternatives to implement the feature request from
> > > https://trac.osgeo.org/gdal/ticket/5762?
> > > What I dream of is to be able to utilize all the nice on-the-fly tweaks
> > > that can be done with VRT at similar speed that Mapserver is reaching
> > > with
> tileindex.
> > That would be a nice enhancement. As usual I guess we need a champion
> > and/or some funding to make this happen.
> > I came across a similar use case not long ago and realized that to get
> > top performance at all zoom levels we'd also need the ability to
> > associate overviews with the VRT. I didn't check if creating external
> > overviews with gdaladdo would work for a VRT already. Maybe it does?
> It does and is even documented in
> http://www.gdal.org/gdal_vrttut.html#gdal_vrttut_overviews.
> VRT supports one overview, but that can itself be a VRT, which in turn can
> point to next VRT overview and so on.
Actually, this is not true (although I might have in the past say so). The doc
currently states :
Overview: This optional element describes one overview level for the band. It
should have a child SourceFilename and SourceBand element. The SourceFilename
may have a relativeToVRT boolean attribute. Multiple elements may be used to
describe multiple overviews.
and I've verified it works (at least they are reported by gdalinfo)
Even
http://www.spatialys.com
