[gdal-dev] EPSG code not recognized from GeoTiff written by GDAL
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Fri May 27 02:59:05 PDT 2016
Hei,
We are facing issues with GeoTiffs that were written by GDAL, after importing them to GeoServer or opening in Desktop GIS.
On file was produced in GRASS and exported using r.out.gdal (GDAL 2.1dev), the other file in R, using rgdal (GDAL2.0.x) with EPSG code 25832.
The rasters seem to miss the AUTHORITY parameter...
QGIS for example detects EPSG 3044 (which is technically identical), and GeoServer considers the CRS as invalid (because of this: http://docs.geonode.org/en/master/tutorials/advanced/geonode_production/adv_gsconfig/crs_handling.html).
Did anyone else experience the same?
Kind regards,
Stefan
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160527/9a0dd6f6/attachment.html>
